View Poll Results: Lower pressure?
Lower pressure gets you a bit more grip around the cones
10
62.50%
It doesn't and/or it is dangerous/not worth it
3
18.75%
Doesn't matter
3
18.75%
Voters: 16. You may not vote on this poll
Who is using lower tire pressure for autocross?
I get 50% yupp and 50% nope on this in real life.
For harmless autocross with a light car (Boxster, Z3/4, Miata, S2000), how many of you think that lower tires pressure gets you more grip on a slightly uneven surface? Old airfield and the like.
So -- any of your three answers could be true in a given situation. Can you add an "all of the above" option?
The correct answer is "it depends". The optimal pressure depends on the car, the tire, and the setup. Also, the current go-to tire, the Bridgestone RE-71R, is pretty pressure agnostic and has performed well within a maybe 10 psi range on the cars I've used it on.
Agree with Pedalfaster, test it and find out what works best in different situations. Don't be afraid of what seems low or high. Also, note that max grip at the expense of response may not be "fast" and vice-versus.
When I ran slicks on a 996 it wanted much lower pressures, 30ish and htrz3 want about 36 with my current setup. If you're not sure, you can chalk around the shoulder of your tire and adjust higher/lower until you're using the shoulder, but not rolling over it.
