Toyo RA-1s/Autocross
Old 05-30-2007, 05:38 PM
fork_included
fork_included's Avatar
RA-1's at 40 psi hot will ensure perfect results.
alot of people run them in the rain keeping the cold pressures the same as they do on a dry track not realizing that the 2-3 psi difference that the tire never achieves is significant in whether the tire grips or slips, it took me a full day of lappin in the rain to realize why my back end kept flying out... its amazing how a little difference in the PSI makes a huge difference in grip levels.
Old 05-31-2007, 01:41 AM
2002M3Drew
2002M3Drew's Avatar
40 PSI? Much higher than I run them on my SC. For autox, I run them at 28F/30R hot, for track 30/32.
Old 05-31-2007, 04:08 AM
jeeper31
jeeper31's Avatar
Do u think I can drive then the 30 miles to an autocross, or should I drive to the event on my streets and change there?
Old 05-31-2007, 08:53 AM
arbeitm
arbeitm's Avatar
I would say you are fine driving on them to the event. If I go with the RA-1's next year, I'm planning on just leaving them on all the time.
Old 05-31-2007, 09:20 AM
Slantnose!
Slantnose!'s Avatar
Absolutely fine driving on them there.
Old 05-31-2007, 10:07 AM
jeeper31
jeeper31's Avatar
Thanks. They have been used so dosn't want to use them up more on the street.
Old 05-31-2007, 02:15 PM
fork_included
wow thats pretty low,
what size tires are you running? i'm using 225/15/50, anything less than 38 my car slides around like a piece of soap
Old 05-31-2007, 02:16 PM
fork_included
if they have little or no tread left (which is good at the track) a police officer may pull you over.
Old 05-31-2007, 03:02 PM
J Silverman
J Silverman's Avatar
Here is some good info on the RA1s:
http://www.philstireservice.com/page...res_toyo_1.htm
It covers temps, tire pressures, camber/caster settings.
So have you gotten the car running yet fork? Havent heard from you in a while. Good to see you still know how to ruffle some feathers.
Old 05-31-2007, 04:51 PM
fork_included
good site
car RAN... and by that i mean i changed all the belts/rollers and it started up again without any trouble, and all my main electronics work considering there isnt much left in there...
right now i have the front suspension completly taken off and a new one just laying there... waiting for some bolts and brake hoses in the mail, ive been really lazy with the car, but it will be done.. eventualy.
Quick Reply: Toyo RA-1s/Autocross
