AUX Input 997.2 TT not working?
Hi All-
I've searched, but can't seem to find the answer to my question...
I can't seem to get my AUX port on my 2012 997.2 TT to show up in the source menu when I plug a device into it. Is there somewhere in PCM 3 where the AUX input needs to be enabled? It doesn't seem like it should be this tough, honestly.
Admittedly not related, but the iPod and USB connectors work fine so it doesn't appear to be an issue with the "input block" as a whole. Any advice is greatly appreciated.
Cheers,
Nate
Cheers,
Nate
I had the same problem: I could switch SOURCE between AM/FM/DISC/iPod/USB, but AUX wouldn't show up. Turned out, you can go to DISC > OPTIONS > "SET DISC / AUX" and enable the AUX. Then AUX will start showing up under SOURCE.
I know, it's been 5 years since the questions, but maybe somebody like me will find this information useful
First, you have to play a CD which makes zero sense.
When I put a CD in the player and started playing it and then selected the OPTION tab, it was showing me the options for something other than the CD which still makes no sense to me. After fumbling back and forth through the horrible interface I finally got the system to display the DISC information while playing the CD. So it looked like this:
Next, when viewing the DISC information, press the OPTION tab across the top (or the OPTION button on the right side of the screen), and you'll see this:
At this point, tap the SET DISC / AUX button and you'll see this:
If you're like me, only the iPod check box will be selected. So just select the USB and AUX check boxes:
Now the SOURCE window will actually show not just the iPod source option but also the USB and AUX sources.
Makes no sense but that's what it took.
