997 Turbo Forum 2005-2012
Common Problems with 6MT 997.1/.2 TT
Old 06-05-2017, 04:51 PM
786's Avatar
Originally Posted by chsu74
Only happens if you buy front and rear mismatched tires. Diffs are robust or you would hear a lot of issues here.
that's odd, so if the front and rear tires are different brands for example the front diff fails? i've never heard of this.
Old 06-05-2017, 06:10 PM
USNA12
USNA12's Avatar
Thank you all for the information! I don't plan on doing a ton to the car if I do get it...other than Europipe exhaust and a tune...maybe ipd plenum and ypipe. The one I am looking at is in excellent condition around 40k miles, just wanted some peace of mind from you gentlemen before I pull the trigger
Old 06-10-2017, 05:27 PM
chsu74
chsu74's Avatar
Originally Posted by El Dario Loco
Not sure what the previous owner did but he had at least 5 other P cars in his garage and have been driving 911:s since the eighties so I would be surprised if he was stingy with tires. Do you think this could be caused by having different thread depth/aged tires front vs back?
I meant if the tire size mounted is different factory spec sizes for front and rear and not different brands of tires.
Kevin from UMW did mention that the front diff is not strong enough for launch control like the 997.2 diffs. Maybe it is not totally failsafe..
Old 06-10-2017, 05:44 PM
786's Avatar
^ gotcha
sounds like a nice example, buy with confidence and enjoy
Quick Reply: Common Problems with 6MT 997.1/.2 TT
