Dension and phone functions
I have the Dension 500S BT in my 997.1 TT. Works fine for playing music but can't get the phone functions on the PCM to work i.e. phone book, phone buttons etc. I read somewhere that I need to disconnect the phone module but don't no how, neither does my indy. Appreciate some help.
/Darius
/Darius
phone module is under left hand seat. Remove the seat, undo the bolts securing the module in place, flip it over to get to the plugs.
disconnect the power plug and the MOST fibre optic connection - install a MOST loop in the MOST connection you have just disconnected to keep the fibre optic circuit continuity - then re-install everything.
Done!
Done!
phone module is under left hand seat. Remove the seat, undo the bolts securing the module in place, flip it over to get to the plugs. disconnect the power plug and the MOST fibre optic connection - install a MOST loop in the MOST connection you have just disconnected to keep the fibre optic circuit continuity - then re-install everything. Done!
1. By the left hand seat do you mean driver side? Mine is left hand drive
2. Do you also need to disable the phone module via the software, i.e. through the dealer?
Thanks again.
I'm in UK so my car is RHD but I think the phone module is always under the RH seat regardless.
No need for any re programming to remove the phone module via software - in fact it is better not to have it removed - that way you can revert to stock at any time if you wish without having to have the car re programmed.
I removed the phone module and frunk mounted cd player - no re coding done and all dension kit works perfectly - you will however see a short error message on each initial boot of the Dension that the cd player is not available - just cancel that and you are done.
Just realised in my first post I said phone module was under the LH seat - That was incorrect - I think it is always under the RH seat regardless of whether the car is LHD or RHD
I'm in UK so my car is RHD but I think the phone module is always under the RH seat regardless. No need for any re programming to remove the phone module via software - in fact it is better not to have it removed - that way you can revert to stock at any time if you wish without having to have the car re programmed. I removed the phone module and frunk mounted cd player - no re coding done and all dension kit works perfectly - you will however see a short error message on each initial boot of the Dension that the cd player is not available - just cancel that and you are done. Just realised in my first post I said phone module was under the LH seat - That was incorrect - I think it is always under the RH seat regardless of whether the car is LHD or RHD
Basic Sponsor
Not sure where you bought, but they should provide some support on this.
Disable the phone module under passenger seat AND bypass it using the CD Bypass Cable (we sell, and others do as well). Then dealer must deprogram it from your vehicle using the Porsche tester.
If you have a changer, and it is not plugged into the 500SBT, bypass it using the same item above.
You can also send Dension a note (we are their primary US distributor) at their website, and you can mention where you purchased it, particularly if they are not providing support (they should).
Otherwise the above should resolve it.
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
2004 C4S Cabriolet
1999 C2 Cab
If you just unplug the phone module and then use the Denison you will get the cd player error message each time you enter the car and switch on the PCM. However if you un code the cd player from the system you will no longer receive this error message. Everything works both ways it's just a case if you can live with the error message our not.....
Before installing the Dension my factory setup included a PCM2.1, Bose Amp, Nav DVD, **NO** CDC, and a factory Phone Module. I removed the phone module from the MOST loop with the fiber loop adapter and unplugged the phone module wire harness so it is no longer connected to the car.
The Bluetooth music streaming is working without an issue, however when I hit the phone button I get a message on the PCM saying "Internal Phone is not available" and the PCM will not let me enter the Phone screens on the radio and I am unable to receive a phone call via Bluetooth.
Do I need the computer to be updated so it is coded as *NOT* having a factory phone for it to work correctly? Or do I need to let the car sit for a few hours before it figures it all out?
Matt
Matt
Basic Sponsor
For non Euro vehicles, you must deprogram the phone if it had at the module.
For Euro cars, in many cases, this may not be necessary.
You will also want the vehicle programmed for a cd changer after the Dension is installed.
Done!
Done!
