Problem with key after replacing battery
It's been awhile since I checked in but I need your help guys!
This topic has probably already been posted in Rennlist somewhere but I can't seem to find it.
I replaced the battery on one of my keys and now only the remote works....i.e. the remote locks/unlocks the doors but the key won't start the car. How do I reprogram it?
BTW, I recently got my 997TT wrapped...I'll post picks shortly!
Cheers guys!
Cheers guys!
Cheers guys!
Cheers guys!
When you insert the key in the ignition and turn it the DME (or security) module transmits and RF signal to the key module/RFID pill. (The RF antenna is located behind the ignition key surround.)
This RF signal is received by the pill, which energizes it and causes it to send its ID. This is received by the antenna and decoded by the DME/security module and if the ID is recognized the starter circuit is enegized and the engine should at least crank and will start if everything else is ok.
