Oil Pressure Sending Unit
Anyone know if the oil pressure sending unit is easy to replace? I think mine is going bad. I got a information message saying low oil pressure when my car went to an idle. Rev it and it would go back up to 5. The message would go away. Then sometimes it would hit zero then back up to 1 1/2 at idle. Checked oil level and I am one bar below the full mark. No signs of an oil leak either. So, that leads me to the oil pressure sending unit. I know this can be an issue with the non-turbos but my search turned up very little on a 2007 997.1tt.
Thank for the help as always!!
As a general rule though the actual oil pressure should be measured with a t-fitting and a real pressure gage to ensure the oil pressure is indeed good and then suspicion can fall more heavily on the sensor/sender.
One doesn't want to replace a perfectly fine sensor/sender when the real problem is well, real too low oil pressure.
