BBI slave reviews???
#46
some food for thought, but i had a difficult time sourcing the correct GT2/GT3 clutch assist spring, which i would say is a near requirement when installing the BBi slave...it may be worth including that spring as a kit option for the cylinder, or at least have the part number included.
#47
#48
Great info, thanks... Does the part number you mention below apply to both 997 and 996? Thanks!
So, I finally decided to try the GT2/GT3 spring (99642308119)...glad i did! the pedal effort i measured was:
- without any spring: 75lbs
- with the stock green spring: 60-65lbs
- with the GT2/GT3 spring (purple): 50-55lbs
Unfortunately, i didn't measure the stock system, with the accumulator to do a full comparison, but i'm sure glad i installed the purple spring...much easier on the legs in stop and go traffic!
