trying to remove drop links = where is the wrench flat?
I'm in the process of a spring / ARB R&R project.
the first step is kicking my butt.
all drop links i've removed in the past have flats to allow wrench counter torquing when removing the nut.
these drop links don't seem to have any flats?????
how are the nuts removed?
Thank you
Craig
if you have a linky to a good AWD car spring R&R and or front ARB R&R, please post them up?
Thank you.
Craig
Thank you
Craig
Thank you.
Craig
Doh!
Porsche progress.
Thanks for the help.
It was obvious once i moved to the rear and saw the rearward facing studs.
#30T hole in the distal end of the stud.
cheers
Porsche progress.
cheers
