Ultimate Motorwerks 997TT Tuning Special $975.00
#32
Question. Living at altitude (Colorado) what would this do for a 997.2 TT?
#34
If you have a Durametric (which I have come to find out isn't able to pull data such as timing), is there some other alternate way to Datalog just to make sure your engine is running properly, not going outside of timing constraints, etc?
#35
I have access to a Durametric, and would like to be able to run diagnostics prior to tuning.
#36
Originally Posted by nzskater
This is a question I've been meaning to ask. Very keen on a tune, but don't want to waste anyone's time (or my money) on starting down the path only to find the car isn't running 100% and needs remediation.
I'd like to be able to pull this more intricate data, have it looked at and then determine if my GIAC tune is allowing my car to operate within healthy tolerances and if not...then I would look to another (UMW) source for a tune.
My fundamental question is: how would I/what can I use/borrow/etc to pull that data?
#38
Durametric can't log enough variables in sufficient quantity (i.e sampling rate) to be useful. You could log maybe 1 or 2 things, but I still think it would only sample once a second.
Kevins tool logs about a dozen sensors at least 25 times a second
There is no comparison
#39
I'm pretty pleased with the tune so far. Just datalogging last night and the data looks pretty good to me.
Kevins tool logs about a dozen sensors at least twice a second.
I just last night logged with my durametric (ver. 6.2.3.5), I'm getting 25 parameters at about 6 to 7 times a second. You must setup the Durametric to the Fastest sampling rate, but it works..
What am I missing here, also with RugRunner saying he can't log timing info?
I can log timing, misfires by cylinder, and timing retardation by cylinder...
Sure Durametric isn't perfect, but it can certainly passable for this kind of stuff..
I'm certainly no expert, so maybe I'm missing something obvious?
#40
Huh? Twice a second is considered fast?
Its more like 25 times a second.
Sorry for the confusion.
#41
#42
RugRunner. you can log timing but KNOCK and detonation cannot be successfully seen (it is not comprehensible) at HIGH sample rates PER cylinder.
Ultimate Motorwerks is selling tuning, the tuning module has the ability to READ and Write multiple tuning files AND datalog for 13 minutes. A "Windows" based desktop computer or laptop is required to view the logs and/or email tuning files. Please note: for those that want a quick and painless tuning method, the tuning module has the ability to be PLUG AND PLAY. READ your stock file, send me the module, I supply a tuned file based on your CAR.. Not canned. IF you want to then datalog (again plug and play)>> it can be done without the use of a computer..
#45
UMW Tune First Impressions
I have owned my TT and used it as a daily driver for the past four years. For more than a year now I have been searching online for the best tune for my car. Finally settled for UMW for two reasons, the first being that they were offering a seasonal discount, and the second and more important being that UMW are selling a tune specifically prepared for every customer car through Kevin the guy behind the company who seems to be a reference on the forum when it comes to Turbos . After having sorted out the financial details of the purchase, I received the tuning device by Fedex and followed the super clear instructions provided by email. The tune happens in two phases, the first being collecting the existing factory data from the car, and in my case performing and logging a twelve minute performance drive in the car. I then emailed the files to UMW and received a day later the tuned software which I downloaded into the car via the tuning device. The process was so easy to do, I initially thought that I had missed something and that the car was still running on its stock software. Until I turned on the ignition and drove away on the 10 mile accommodation run recommended by Kevin. The car felt immediately different, even at the slightest contact with the gas pedal, you feel it super responsive and overly alert. The performance curve is more linear, you get a constant stream of power rather than a lag and then a sudden burst of power you get in stock mode. It is really surprising to see how much the tune ameliorates the character of the car at low rpms and in normal city driving conditions. After having passed the 15 mile mark, I finally got to try flooring the pedal, and boy was I in for a big surprise ! It's a Turbo on steroids, so much so that I quickly stopped the maneuver as traffic had been fairly dense, and flooring the pedal got me quickly too close to the car in front of me that seemed pretty far away at first.
It's my second day running the tune, and the weekend is here so I get to discover more of my "new car". To all the guys on the fence about a tune I tell you to go for it, it's worth every penny spent. My experience with Kevin was very professional, I got the feeling that he really knows what he is doing, and that my car and its internal engine components are within their safety limits with this tune.
