For those with bbs LMs and E88s... Tpms question
From what I understand and seen myself, then valve stem opening on bbs LMs and e88s are not the right size for our oem tpms. What are you guys doing to maintain tpms?
Edwin
Edwin
Code it out.
Any good machine shop can take care of it once you know the exact dimension for the opening
Thanks for the comments folks. I've thought of a few options
That will be my last resort. My turbo isn't a daily so I need something that will tell me if the tire pressure is low as I don't check every time I drive the car.
Thanks. This will be my second option.
I guess to each his own... there are ways around this so if you like the wheels, get it and figure it out
- TPMS Band Strap
- Drill out holes
- use aftermarket TPMS sensor system (Orange Electronics for example)
- Code out
