My spun camshaft story
#61
This is from my P car guy in the biz:
"There is a small metal plug that's inside the hollow intake cam that somehow moves further into the cam and blocks the oil passages for the lifters. When the passage is blocked the oil will not flow and pump up the VarioCam Plus portion of the lifters and you end up not getting the higher lift profile of the cam. This makes that side of the engine not produce power in the upper RPM range when the valve are to be at high lift. This feature is only on the turbo Mezger engines and not the ones in the GT3. "
It's a big dealer, only seen a few, felt it was pretty rare.
#62
#63
Greg, it's not a plug but a metal sleeve. Since I have pinned a handful of these camshafts. It is a loose sleeve that rotates.. Engine crankshaft harmonics on this engine doesn't come into play with the relative low RPM redline. Porsche has done a decent job at balancing the crankshaft, rods and pistons. The flat 6 is inherently balanced. If balancing was an issue, the 130mm intake camshaft bolt would be shaken out of the camshaft. You'd also have the exhaust cam bolts back out. And since there are ZERO guide pins or lock nuts to secure the vario cam or exhaust cam gear>>they would loosen up. WE would see camshaft deviation errors in the statistical population. To date, I haven't seen or heard of any.
Like I wrote in a earlier post, it's a "lottery" type failure. When the sleeve rotates, your numbers up..
#64
#65
The camshaft supplier to Porsche had to invent a new process. New design> manufacturing process.
The intake camshaft is hollow, a bolt passes thru the Vario-cam module and threads into the hollow portion of the camshaft. Between the vario-cam module and the fastening bolt threads (or attachment point) is the sleeve with holes drilled in it. The constant cycling of the vario-cam solenoid will pulse the oil thru the sleeve as the camshaft advances. I believe that it's the pulse that is loosening up the sleeve that is PRESS FIT, in the hollow intake camshaft..
If we had a crankshaft vibration or harmonic caused by the crankshaft rotating assy in "this" engine we would have more components loosening up.
The camshaft sleeve bore has deviations between camshafts due to manufacturing tolerance errors. One of the cures to fix this is to pin the sleeve. This is a permanent fix. The sleeve will not be able to rotate in the gun drilled hollow bore after the fix.
#66
As I understand it, the turbo has vario cam plus (changes timing and lift), whereas GT3 has vario cam (just changes timing). Could that explain why the issue is just with the turbo and not GT3?
#67
I don't suppose you have an assembly diagram, or photos showing the physical appearances and location of each components involved?
Also what was the new process the manufacturer had to invent to stop the problem? Was it just a tighter interference fit? Or was the oil recess /hole in the bush expanded/increased along the length of the bush? So if it turned the oil still had adequate passage?
#68
The new process is in reference to building this new camshaft design vs the 996TT camshaft (no bushing).
Cincyscott has posted pictures of his camshaft failures which shows the sleeve.
The repair process requires the relocation of the sleeve and pinning it to keep if in place.
#69
#70
Lots of good discussion here, thanks all for the info!
I called that guy from Circle you mentioned and left 2 separate voicemails and they never called back, so I guess they werent too interested in selling it to me..
Even for the mileage you have on your car, those look like retail prices.. there is some serious markup on these warranties; retail on my 3400 policy was almost 5K.
Gotgolf,
So I finally got ahold of the guy you recommended.. And a big thanks to you! Same policy was over 400 cheaper, so I decided to upgrade and get the 3/36 policy..
#71
Does this issue always happen in the same place? Same camshaft, same sleeve?
If so, doesn't that mean it is very likely a manufacturing defect (like others here have said)--assuming there are other sleeves elsewhere.
Or, are there two (or four, or eight...) sleeves, and this can happen to any of them?
#72
#73
This reminds me of the header and valve guide issues on my old F355. Fix it the right way (i.e. pin the sleeve) and forget it. I'm leaning toward self insurance sine the cost of the warranty vs the cost of the cam repair has about a 3 yr break even. Since I plan to put only 2-3k miles a year on my car, it is a chance worth taking.
Btw this ignore feature is really nice
#74
Louis, you have two intake cams that have the sleeve. I called it a lottery because you don't know which one will fail and when it will fail. It may never fail... This is a repair that I would just wait till you get the CEL.
#75
I was told these engines suffer from a low speed harmonic and it is this vibration that loosens the actuator bolts, breaks Oil pump gears etc. Not theory, but fact. It happened to me. Most have no understanding of this and the common thought is these engines are naturally balanced. Not true. Many have broken crankshafts. A VW is a flat four engine that would have the same quality and those cranks break all the time from the same effect. An understanding of engine balance and the difference between the two is important.
As for the sleeves coming loose but not the bolt, the sleeves are not held in the cam by the tension of the bolt stretch, but by the interference fit into the camshaft. The motion of the actuator certainly could attribute to the sleeve coming loose. No question. But the high frequency vibrations induced into the Valve train would have a greater effect. The motion of the actuator is a lot slower and may have a lesser effect.
