PET 7.3 and Windows 10 - NOT working
Just a word of warning - PET 7.3 doesn't seem to work under windows 10 so hold off upgrading if you want to keep using PET.
I now get a Hardlock error 14 after upgrading to win10. Haven't found a way round it yet!!
Have you tried running it in compatibility mode? Thanks for the heads up!
I run a virtual machine on my system, and have it run Vista (old copy I had), and it will then run in Windows 8.1 or 10. Just FYI. You simply run the VM and then can rub all sorts of older apps you may need/want.
You can check out VMware for a free personal use version HERE ...No affiliation...but works well.
Good luck,
DC
Good luck,
DC
Interesting that you can get it to run in win 10 in a virtual machine. I am running win 10 in a virtual machine on a Mac running parallels. This worked fine using 8.1 but not win 10!!
I can always set up another VM under Parallels and run 8.1 to use PET if I need but I'm curious as to why it doesn't run under parallels
DC
