Which Race Ramps (Car Service Ramps) for my 997 Turbo?
Hi
I want to buy some Race Ramps (Car Service Ramps) for my 997 Turbo. Due to the fact that I´m from germany, shipping costs are quite high (there´s no reseller over here, just one in belgium). I need to make sure that I´m ordering the right ones
- Does anyone have personal experience which Race Ramps will work on a 997 Turbo? I´m afraid of buying some Car Service Ramps from Race Ramps and getting problems with the angle/low profile of my car (it has the OEM PASM).
- If so, what kind of ramps would you consider or have you bought? I´m thinking of getting the 12" or the 14" (see attached pictures), but I´m not sure yet (12" for a 305 wheel might be a little bit less, 14" seems better).
Thanks in advance!
Thanks in advance!
No 997 Turbo experience but for my 996 Turbo I found Rhino Ramps worked pretty good.
I could back the rear of the car up on the ramps to give me room to change the oil and filter.
Couple of things: The ramps were too high/steep to work under the front of the car. If you want/need to drive the front of the car up on ramps Rhino Ramps aren't for you.
Before I bought the Rhino Ramps I got permission to take one out to my car and while not use it of course see if it would work at the rear. It did but not at the front so I was aware of this.
The Turbo's rear tires are quite wide and the ramps I had were not as wide but I centered the ramps and the car was supported just fine.
Thanks for your replies so far. Rhino Ramps aren´t available over here too and seem to be harder to get (ship) than the Race Ramps. But anyway, what Rhino Ramps (model) do you have (especially @nuclearfishin)? Do you have a picture with the 996tt or 997tt "liftet" up at the back?
I'm interested in this as well- RaceRamps seems to have a significant advantage in terms of incline, and the XT is also 1.5" higher
Here's a good "how to tell" guidance from the manufacturer:
http://www.raceramps.com/xtenders-fo...ace-ramps.aspx
Will you be getting it from DUXE or otherwise?
Best wishes from Luxembourg!
I bought the Race Ramps Xt-2 67 inch along with the 10" wheel cribs to do service on my Saleen and TT. I can back the saleen up on it no problem without it scraping and the saleen is lower with a greater front overhang. Haven't done it yet with the TT since I borrowed a lift for my last oil change.
It should work just fine. If you want me to I could throw it up on the ramps tonight and report back just to be sure. Just let me know.
I couldn't justify the cost of a lift in my garage at the moment so this was a good solution for me. So far I did a coolant change and I had a wonderful amount of clearance for the car. It feels a whole lot safer putting it up with these rather than jack stands. Quality product and worth the money in my opinion despite the high cost.
One other thing. I highly recommend the 2 piece for even greater access to your car. Worth the extra money.
Thanks for all of your replies!
@Luxembourger: Yes. I wanz to order ftom DUXE, if I'm going with the Race Ramps.
@Eviligloo: Thanks. That would be perfekt if you try it! Thanks in advance
I don't know if anyone does anything like these in the USA, but I've been toying with buying a set for a while.
http://www.cjautos.eu/mobile/Product...oductCode=CR01
Please note that I have coilovers so my car is lower than yours is. I had considerable difficulty getting my car on a tow truck because of the front clearance. That being said it clears the race ramps just fine. The matching wheel cribs are nice for the front so i can level the car out and do quick and easy oil changes and maintenance. The nice thing about the XT-2 is that you have 10" of clearance from the bottom of the wheel which gives you room to work under there.
turb0 (09-16-2023)
(1) I'm hearing some cars require a lead on ramp like this:http://www.ebay.co.uk/itm/BLUE-LEAD-...item4d04310104. Would you be able to drive the 997.1tt onto this ramp without a lead on ramp?
(2) How's the front clearance for 997tt's. Any scrapping of the spoilers?
Found this:
http://www.cjautosheywood.co.uk/bigramps.pdf
The article says "most low slung cars will manage the shallow 16 degree slope". Fair enough.. but would this be enough for a 997tt?
@Nuclearfishin: RhinoRamps claims a 17 degree incline (of the ramp). Have you experienced any spoiler scratching when backing up?
@Luxembourger they do a low profile version now too.
This also locks in 4 different heights, and hoses can be detached if required.
I'm tempted to get a pair and see how they do.
