No additional Ducting is required. Clips hold well from underneath....I would suggest moving it slightly closer to the hood, as the template places it too far forward...looks better close to edge of hood as opposed to farther away...I did mine myself and came out pretty good.... Good luck DC
hi Rock, where did you get the kit? It looks fantastic, and you did a great job mounting it!
Thanks! I used the Rennline Kit (note the actual vent is an OEM part). The benefit of their kit is the mesh is pre-cut and the clips work very well...Also, for a first time attempt it is nice to have the template, though you could carefully trace the vent itself. There is not a lot of tolerance with the opening, so you just need to cut very carefully and it looks great...Pops right in and is snug!
What tool (s) did you use to cut the urethane bumper?
Thanks!
Hi....
I covered the top with blue painters tape.....then put the template over that....and cut it with a super fine metal cutting blade on a high quality SKIL jigsaw....Works great....
