Pcm 2.1 replacement
It is much cheaper, and if it meets your needs...then great. Just an FYI on that system.
DC
Pcm 2.1 replacement
The Dension 500BT is a workable solution on the current firmware. I installed mine myself, took about two hours (mostly because I'd never done any electrical work in a car before).
I have mine hooked up to constant power. It generates a CD changer error but this is a false alert.
Bluetooth calling works 100%; if I'm on a call when I start the car it transfers over. I can call via the PCM or the phone.
Bluetooth streaming works 100%; it connects every time and audio quality is decent enough. It automatically starts playing when I start the car (from we're it left off).
USB connectivity works 100%; connecting to the Dension charges the phone and it automatically changes the input on the PCM/Dension to USB (better sound quality than Bluetooth).
The issue with that system (and reason it is so cheap) is that it is simply and RF Modulator and sends the signal through the radio antenna...That technically limits the quality it can transmit. The others use a more sophisticated Fiber Optic system that allows much better quality and interfacing...but not without issues either...And cost...
DC
DC
C
Pcm 2.1 replacement
I went through 4 firmware revisions before I got to one that worked consistently. It was a chore, and I spent hours communicating with Eric from Bumperplugs, but Dension delivered in the end. The older versions were buggy as hell, so could imagine that yours never worked well.
I used mine to dial in to a conference call this morning, and no one complained, so guessing it works well enough!
Unit works flawless for me. I never updated my firmware. I am on 50. My solution was to tap into the antenna power out. White wire back of PCM. The CD not found error can be easily be taken care of with the PWIS. I have not tried the durametric yet. Most say it can't be done but I disagree. Since I can disable the TPMS gateway, I am sure I can disable the cd changer. Just have not worried about it.
Rocky Mountain High
I have had no such issues with the Mobridge unit. The call quality is very good and it works very well through the menus on the PCM unit. Bluetooth music streaming works well too.
Thanks again...
DC
Images below that may be helpful to some considering it. Error message I get as well as diagram, the unit connections and where I mounted the input device:
I have sat down and looked at Durametric perhaps a total of five times. I have made two changes and those were related to the TPMS. I loaded the last version and it is a piece of tihS. Had to go back to an earlier version. In fact, I have all the firmware updates to Durametric because some are awful. The latest one crashes a bunch.
DC
I've tried loading firmware on my Dension 500s bt and i have so many bluetooth issues with my LG G3 phone running latest Android 5.0.2. Any pointers? It connects but cuts out within seconds, connects and disconnects all the time. Phone calls same thing. I can only use the aux feature without issues.
