TPC's magic PASM controller (DSC)
1. Ride height adjustability
2. Corner balance adjustability
3. Easability of spring rate change
4. Mechanically better suited for stiffer springs and lower ride height
For normal street use none of the above is really noticeable but for extreme usage they become more apparent. With the coilovers/stiffer springs some of the lower range suppleness is taken away in favor for better movement control of higher range stiffness during very high g loads from very sticky tires.
Thanks Tom, both answers make perfect sense.
The coilover kit has the following advantages over oem struts-
From my perspective, it is more comfortable with the TPC DSC, but not due to being softer. It's more comfortable because the car better adapts to changes in the road surface. Before, it dealt with this by making it soft. Now, it deals with it by adjusting the suspension more effectively. Instead of bouncing around on rough sections of road I find the car is firmer but more settled.
A few times I second guessed it due to the fact that it sounded rough, but realized that the noise did not relate to significant physical impact. Don't expect it to behave like a hovercraft... but it is definitely more comfortable than stock (or in my case with GMG springs).
Nzskater's description is correct. DSC doesn't make it softer, it makes the OEM suspension better damped over and after bumps. Better damping makes the car more stable over and after bumps which the driver perceive as more comfortable and stable. With the much reduced or eliminated oscillation the toe-steering effect is gone making more grip. And yes the suspension stiffens up at the appropriate corner(s) of the car when you're on it.
The car has a better ride and most noticeable is the elimination of the "float" in the comfort mode. The level 2 and 3 are also amazing. It doesn't have the harshness of the OEM set up in sport mode. A great investment in my opinion and it's plug and play.
I wonder why Porsche set the car up the way they did from the factory? Do they think most Americans like the floaty ride?
circling back around on this. I may be able to buy one of these, but I'm questioning how it feels on the normal setting.
I like float and soft and cushy on setting 1. Am I going to be disappointed with the DSC given my predilection for not feeling bumps?
thanks.
thanks.
in mode 1, i find the ride perfect even on our 3rd world honolulu streets- it's very comfortable ride without the float & less front end dip on braking.
When i drive wifes 07 Boxster S -no PASM- the ride on her car is much stiffer & you can feel the road more than on my TT in mode 1.
my previous car was 02 996C2- put on the porsche X-74 suspension & ride was stiff but not jarring. TT ride with DSC is much better on street.
