Alignment recommendations
Does anyone have a recommendation for a good street/dd alignment spec?
I have a mix of highway/city/twisties that I drive. Today, I'm at stock 997 TT specs and the front end tramlines and doesn't feel as planted as i would prefer.
I have eibach lowering springs and adjustable sways if that matters. Thanks!
--Scott
--Scott
Because the shop I was using is incompetent, I was able to sample two different alignments in rapid sequence. One had -1.5* camber in the front and -1.0* camber in the rear, and the other had the opposite, -1.0* in front and -1.5* in the rear. No toe-in to speak of. The former is so much sharper and enjoyable.
LP
LP
LP
LP
On my GT3 (7.1) I'm running a conservative track setup that rides great on street as well.
-2.2 front
-2.5 back
1/16 out front toe
3/16 in back toe
Sway bars softer front and hard back
Turret rear toe links with locking plates
Works great with stock MPSS 19" and NT01 18"
Ran similar on my 6tt but a bit more front camber
-2.2 front
-2.5 back
1/16 out front toe
3/16 in back toe
After doing some research, I don't think I'm likely to get much more than -1 in front without different strut mounts. Sound right to you guys?
GL
Art
The max you can go on the fronts with the stock suspension is about -1.2. I had my alignment done last year after installing GMG springs and based on the recommendation from most folks on the forums I went with -1.2 upfront with neutral Toe and -1.8 on the rears. Car is very stable and planted on turns, this setup works well on the street and has a nice aesthetic stance as wheel.
GL
Art
GL
Art
I'm not 100% sure, but I know to access the top of the rear shocks you need to take apart the interior of the rear, and when I brought it in for alignment they definitely didn't do that. I'm sure someone with more experience can chime in.
Wright Motorsport is in your backyard, I don't think you will get much better than that for car setup. Their IMSA teams have been the fastest on the track lately, and the drivers have attributed it to suspension setup by WMS.
http://www.wrightmotorsports.com/
Trucker
GL
Art
GL
Art
