Question about Turbo Oil cooling
They are oiled...but not a separate system. All oil integrated and contained in crankcase, oil tank and small area in each turbo...but all part of engine oil system - not separate.
If you have the GT1 engine, you have a 2 stage dry sump. The oil that feeds the engine main bearings and rod bearings feeds the turbochargers. The oil supply lines to each turbocharger are pressure fed off each bank.
The bearing housings 3K KO4's are water-cooled. To promote maximum life out the turbine side sealing rings, I recommend a cool down cycle or 30 to 45 seconds of engine idle time prior to engine shutdown.
Sid
