Loss of performance above 4000 rpm on full throttle (WOT)
Wanted to get some input on what I've been experiencing over the past week with my 07 Turbo, 49K miles.
During WOT (but not every time), I experience a lag/loss of performance above 4000 rpm. Feels like a huge drop in HP. Wanted to additionally note that the turbo pressure doesn't drop. I've driven a few times since and had the engine shut off when coming to a stop at a stop light. The car is now parked until I can find a shop to look at it.
After searching the forum, it sounds like the problem could be related to:
- Bad or dirty MAF
- Cracked or damaged coil pack
- Spark plugs (Probably not the issue since I've recently had mine replaced and gapped for tune)
Hoping to find a decent shop here in Phoenix/Scottsdale in the next few days...if anyone has a recommendation, please feel free to reply or PM me.
- Bad or dirty MAF
Basic Sponsor
Maybe a boost leak? I would check to make sure that you don't have a boost leak somewhere.
I would also check to make sure that the VTG actuators have full motion.
You are in Phoenix it could be something as simple as a bad tank of gas mixed with insane heat.
Hope that helps some good luck!
-Mitch
-Mitch
PORSCHE EXPERT GROUP - TIM | GRANT | HJ | ANDREW | JARED
COBBTUNING.COM | LIKE US ON FACEBOOK | SEARCH KNOWLEDGE BASE |CONTACT US
- Bad or dirty MAF
- Bad or dirty MAF
That was my thought at first as well. First time it happened was on a 111 degree F day. But, I've driven the car at night a couple of times and have experienced a couple of lagging WOT pulls too.
Here is a quick, diagnostic procedure. Fill the tank with 50/50 mix of race gas. If the car pull like it previously did and strong>>your tuning most likely has too much timing. Timing retard is taking place. You can also monitor your exhaust pipes. When the engine goes into stress, for component/engine protection>your fueling Lambda drops causing black tailpipes.
Check and see if the vacuum line came off th FPR on the passenger side you can usually feel/see it.... Happens a lot Zip tie the bugger on...
Basic Sponsor
Sounds like it could be a vacuum leak. Stalling at lights would be consistent with that, but having an intermittent vacuum leak would be... strange. Did you check the computer to see if there were and stored or pending codes?
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
John@Fabspeed.com
215-618-9796
www.Fabspeed.com
another note...after starting up my car yesterday and taking it to red line one more time, I think my clutch is starting to slip...won't be able to try that until I get the clutch worked on.
I'm shopping for an OBD reader right now as I type this.
Former Sponsor
We're located in Tempe near the 101/202 interchange, and would be more than happy to take a look at the car. We're intimately familiar with the 997 Turbo, whether it's stock, tuned, or has 1500whp+, and do diagnostics/repairs and service in addition to performance and ECU tuning in-house.
Give me a call if you'd like to set something up, 480-317-9911.
Thanks,
Sam
Thanks,
Sam
Interesting insight, but what exactly do you mean by "black tailpipes"? When my car was 100% stock the inside of my tailpipes had plenty of black soot. and now with a tune they are about the same to slightly more sooty (is that a word LOL!) on the inside. So does "black tailpipes" mean the entire exterior of the pipes is also black?
thanks for clarifying
Art
Run your finger inside the tips. You will see black soot on your fingers (more than normal). You can also see black soot on your bumper cover. Periodically one should examine the tips to keep a baseline. Datalogging your engine performance and logging Lambda and knock retard is a good thing.
If you drive it hard enough your tips will turn white!!!
You also can be running good one day, and have a fuel pump issue (run lean) High knock retard with heavy fueling=soot
Put another way, if you watch your tips, you will quickly know when something isn't correct.
