Tire pressue
31/37 cold
Ends up around 34/40 hot.
Handles best with 6 lbs difference F/R
Basic Sponsor
I'm with Terry.
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
2004 C4S Cabriolet
1999 C2 Cab
With respect to what it says on the door, would not that be a generalization and greatly depend on the tires you are running??
Also recommend a quality/accurate tire gauge as the Porsche/aftermarket tpms readings can be off by several pounds?
Asking not saying.
Asking not saying.
For the past couple of weeks I was going to start my own thread on this topic. I'll tack on my questions to this one.
QUs
1. how often to you check the tire pressures?
2. When you adjust the pressure, do you over inflate by a hair assuming that the pressure leaks over time.
3. how accurate are you TPMS? Are there more accurate TPMS than the OEMs?
4. Do you have a compressor at home? What kind?
ANS
1. Every month
2. I usually over inflate by 1psi
3. My OEM TPMS are not very accurate, they range from -2psi-+2psi
4. I have an 12v tire inflator. It's OK. It takes an age to inflate, get quite hot and is loud, but it does put air in the tire.
QUs
ANS
1. Every month
