Buyer Beware! What to look for when purchasing sport catalytic converters…
Basic Sponsor
When investing in high performance aftermarket catalytic converters for your high-end sports car or exotic vehicle, it's important to know what you're actually buying!
Not all sport cats are created equal. Be sure you're getting the best quality by looking for the HJS logo stamping on the side of the cat housing. If they're not HJS, then you aren't getting your money's worth! Inferior quality cats often fail prematurely, causing dangerous debris to be pulled into the engine and resulting in costly repairs. Non-HJS cats often utilize support rods to hold the core together, which impedes flow and negatively impacts performance. Genuine HJS cats use durable tri-metallic cores which are capable of handling high-horsepower loads without issue.
Fabspeed Motorsport uses only the highest-quality genuine HJS catalytic converters, imported directly from Germany. Fabspeed is the second-largest purchaser of HJS cats in the world, and the largest in the western hemisphere.
Don't trust the safety and performance of your vehicle to anything less than genuine HJS sport cats!
Contact Fabspeed Motorsport for more information...
http://www.fabspeed.com
info@fabspeed.com
1.215.646.4945
info@fabspeed.com
1.215.646.4945
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
John@Fabspeed.com
215-618-9796
www.Fabspeed.com
Thanks for the clip. It was generally informative but I will say Joe didn't do himself any favors and came across as being quite shifty with the repetition and eyes moving all over the place like a dodgy used car salesman. No offense but that's how it looks so don't shoot the messenger ok. You may need to consider a retake to fix that imho.
Anyway, I got the bit about Tubi cats being total crap, makes sense and would answer for what I personally found where that system took power away in the mid range @ 4000rpms upward. Good to know what was actually causing it so thanks to Joe for the explanation there. I can see why a tune was needed to prop up the loss. Now users know why they have to get a tune after.
Now what I didn't quite understand was Joe's mutterings about "Eurohype" assuming he could only be referring to Europipe? Love to hear what Joe was actually trying to say because if he had anything genuinely credible to add about EP's cats then he ought to say it without the need to be tricky. Again that is how it looks. As a user I certainly did not experience any restrictions.
So, what is the real story on the "Eurohype" cats?
As i said, I found what he had to say was quite informative if not overly repetitious at times and whilst Tubi was squarely in his firing line he got himself carried away basically casting dispersions over "others out there" without being specific to who these "others" actually were, instead of ending it. You see once you start throwing **** publicly at your direct competition you really need to be specific and crystal clear with what your argument is with them, not just select one out as an example and then tar others with the same brush in the process. To me that is just very bad form.
whatever...
Obviously I have pointed something out that doesn't suit you personally. Let me guess, You are a Tubi owner or some other under-performing over-rated droning POS? If so then it may pay for you to take notes on what Joe said. Mind you an Emitec cat could also fail for a number of reasons and it is not as if Joe was specific with exactly why that Tubi cat failed. He just alluded to the fact it had unnecessary obstructions in the way the core was set in the case. Maybe we could have some more clarity on that as well....in fact is in order given the size of the axe he laid into Tubi.
I'm not sure where he is going with the "Eurohype" reference, but he mentions that all the cores for the high end vehicles, including the one he was holding , are made by Emitec. If you look on EP's website, they too are using Emitec cats, so he pretty much confirmed why no one has had any CEL issues with EP exhaust........but still wondering what the "Eurohype" is all about???
Trucker
I did not watch the video clip. And I do not know what was said, etc...BUT...folks...Fabspeed is a fairly old US shop and has sold a lot of aftermarket parts for a long time...they have an excellent reputation with long term customers or they would not have survived...so be careful which way you steer this thread.
(I am going to repeat what I have said before...). I paid $4,500 and bought a 2-can Tubi. IMHO, waste of money as it did not make my 7TT sound too exciting. Otherwise, it fit really great, no CEL, and I could not tell the difference in power. It is still on the car and it just "ok". I also bought an Akro for my GT2 and I found it too loud and felt like a squid so I got rid of the exhaust and then the car. The guy who bought the Akro loves it... I recently picked up a GT2RS and I am going to leave the exhaust alone.
I find when competitors throw **** at one another there is usually a double edged sword. An owner getting himself personally involved also doesn't allow for any buffer if and when questions are raised over certain claims being made....
Fwiw my tubi also did not throw a CEL, but in stock tune certainly felt muted/dulled in the mid-range upward 4k rpm in comparison to the stock system...no question about that. In so far as fit, that was nothing flash either and a few adjustments were required along the way. Nothing insurmountable but a precision fit it was most certainly not. So I would concur with FS 100% that at the price Tubi charge they should have at the least provided the client with quality to the standard of the OEM system, which they clearly did not, and something that was a precision fit, also which it was not. Performance also dubious at best and sound whilst subjective was very very bland and ordinary..
I acknowledge FS is a longstanding shop and a pioneer of many AM exhaust products....no issue there whatsoever. However, I will say when a business owner becomes personally involved in putting the axe into a competitors product publicly then there needs to be total clarity on all fronts. It is a dangerous game especially if making fleeting vague comments and also altering a competitors name to make fun out it. Needless to add any cat can fail as I said earlier, and whilst Joe explained the differences in the way the Tubi core was retained in comparison to his own there was nothing said at all to clarify why the Tubi cats were actually failing in this car. That would have been in order imho given the tone of the message was indicating the cats had failed due to the pins.
Granted the flow has been impeded with those 4 pins going through the cores, that goes without saying. But did it cause the cats to fail? Well surely FS knows why and should enlighten the members?
In so far as anyone steering the thread goes, it is FS'ds thread, so at this stage in the game the ball is in their court now and as questions have been raised they should explain themselves to the members on the obvious weaknesses in their story now pointed out. Am i as a member to now apologize for asking questions that go to the very core of their key argument? I don't think so.
Tubi Tubi Tubi
I know one thing for sure, this FS expose' on Tubi's cats would not bode well for any of their systems...even the new one for 991tt...yikes! You don't wan't restrictions in the cats! I'd be personally asking CG for the details on what have they done to yours. That maybe one reason why that system drones so badly?
I have the complete fabspeed exhaust to include both the x-pipe and muffler bypass pipes. I like to switch between the two depending on what mood I'm in and how loud I want it. I can say with confidence that the fabspeed exhaust has DEFINITELY improved my performance. As some of you know I have made plenty quarter mile passes and am very meticulous about logging my data. I only perform one upgrade at a time and do plenty of runs in between so I know exactly what impact each upgrade has. The exhaust made a difference of .5-.6 seconds in the quarter mile which was about the same improvement I saw when running 110 race gas. Never a CEL and very consistent. I plan on timing my car this Friday with a new IPD plenum installed and will report results here. Objective results. As for Fabspeed, great product which I'm very happy with.
Hi it's joe Fabiani the president of fabspeed Motorsport USA.
I will make another video explanation factual documentary Tuesday. Bottom line European tuning exhaust companies often charge 300 % to 400% more than a USA quality company like fabspeed Motorsport and advertise HJS German Emitec catalytic converters BUT are giving out lousy no name generic restrictive catalytic converters!
Often the German, Italian and other European companies truly hope and expect USA exotic car customers to believe in the bull**** logical that an German or Italian exotic must logically and surely respond to a very expensive you get what you pay for exhaust system from Europe since the cars were originally manufactured in Europe.
That European paradim fallacy and overpaying had been going on for 30 years. I remember a shop trying to sell me a RUF Germany catbypass pipe and rear muffler for my 1984 3.2 liter carrera for $4500 complete ............I said no goddamn way........ They said its a German RUF system. Get over it.
155 Commerce Drive
Fort Washington, PA. 19034
www.Fabspeed.com
P: 215-646-4945
F: 215-646-9828
Exotic Car Performance Experts
Porsche, Ferrari, Lamborghini, McLaren, Maserati, Bentley, Aston Martin, BMW, Audi and Jaguar.
31 year PCA Club member supporter
14 year Ferrari Club member
1st ever financial supporter of Porsche Fans/ Rennlist
155 Commerce Drive
www.Fabspeed.com
P: 215-646-4945
F: 215-646-9828
And totally agree where any Ruf system is concerned....laughable...a complete utter rip off. Can't understand for the life of me how they charge what they do....and get away with it.
Further development of the metal matrix by Cargraphic / Emitec / HJS
HD-Matrix Design (High Durability Metal catalyst)
Ø 130mm big volume 200 cell highflow version exclusiv for Cargraphic with special trimetal plating, fully OBD2 compliant (no CEL),
no DME/ECU programming required
