Couple interior sqeaks
Just picked up an 08 turbo cab few weeks ago, love the car, have only driven home from dealer then to shop for an alignment approx. 150 miles pre alignment.
Car was quite no squeaks originally. In order to get a turbo spec alignment had to put urethane offset bushings on the control arms. On the ride back I notice some noises in both door panels and steering column constant even on smooth pavement.
The temp was also about 18 degrees maybe 20 less than the original ride. So not sure if weather related or not. I am driving the car to Florida wanted to get it resolved beforehand.
Before I change the bushings back and re align. Just wondering if anyone had same experience? Could it be the forces on the body from more aggressive alignment?
I have an 08 GT3RS with 9k miles and no interior panel noises.
Thanks in advance!
Thanks in advance!
Trucker
Alignment should not impact NVH or BSR at least you could not have changed it that much? What would affect NVH or BSR based on your before/after would be: a) the lower the temp the higher the noise transmissibility b) tire pressure was changed?...Check it. c) Bushing durometer will have an impact for sure. Not sure what about your before/after but anyone who has gone to different polymers or solid bushings, mounts can you tell you that they picked up a lot more road induced noise... d) finally I am assuming that your before/after test was on the same exact section of road, road speed, and even engine speed...
If I were you...I would just leave it alone and take it to Florida...warm weather will loosen up all the rubber stuff and you will have your top down anyhow!
After owning several P cars I can tell you with authority they don't like cold weather. In Summer my car has zero squeaks and rattles. When the outside temp drops below like 50 forget it. Dash squeaks, door speaker rattles, etc. Fortunately, I drive my car 95% of the time in warm weather. Don't spend too much time trying to figure out how to resolve the problem. By the time you get to Fla it will probably be nice and quiet inside.
