Turbo Break-in Tips
Turbo Break-in Tips
While some here will certainly think....Not Again....
Picking up my car tomorrow. Its got 17 kms on it now. Will take it for a 500 km drive and will keep it below 4200 rpms while varying engine speeds throughout the trip. Upon completion of the trip i am intending to drive it aggressively and do some accelleration runs from standstill and redlining it etc...
All comments welcome.............
Always vary your rpm, even up to redline and you'll be fine.
I would think that the idling for a minute would have to do with allowing the turbos to cool before shutting the car down. I used to do this in my Audi TT and my 96 993 turbo.
good question-it seems to be the recommendation of many prople who are engine experts, but you are right-porsche doesn't seem to recommend it. i have a turbocharged airplane, and i afford the same care to that engine. i have never read, though, that letting it idle for a couple minutes has proven to help, like in a study.
997TT Manual Says Idle Before Shutdown
I think it's around page 83 of the 997TT operating manual. It says that after a hard drive (whatever that means), idle the car for 2 minutes before shutdown, but it doesn't explain why this is recommended. So I sit and idle whereever I go.
One more quick thing I remember about something I had read on rennlist when I picked up my first porsche. Someone had recommended a way to seat the rings during break in by keeping the car in a high gear (5th or 6th) at low speeds and getting on the throttle. The car would stay well under 4200 rpm, but would build up a good deal of pressure in the combustion chamber. This was for a NA engine, so I'm not sure if this method would have any ill effects on the turbocharging system.
From the Carrera's owner's manual:
"Never lug the engine in high gear at low speeds. This rule applies at all times, not just during the break-in period"
1) No you get it up to high RPM in a low gear so the load is minimal and run up the revs and let them coast down. This will expand and seat the piston rings. So pu tit in 2nd and run up to 6000+ and just take your foot off and let it engine brake down
2) This car has a real race engine in it, not a pretender. Drive it normal to hard during break-in
3) You can idle parked at the end, but a better way is to just take the last two miles at normal to slow engine speeds so as not to coke the oil
In any case...have fun. This is why you bought it, isn't it?
Allegretto, thanks for the clarification. BTW, are you a musician or the inventor of the famous laser? Just figured I'd ask considering your monoker.
