Oil change '07 tt, anyone done it by himself or watched it being done?
Really think 20K is too long for the 1st oil change. Need the 20K-dealer-oil-change for warranty purposes, but want to change the oil at 10K miles. Dealer price of just oil change $350. However, the filter is $18, 10 qts oil @ $8ea which means a saving of $250. Not bad for less than an hours work.
Plus some hands-on guys like to do the change themselves to make sure everything is done carefully and correctly. Anyone out there already try the oil change? Looks like the filter is easy enough to locate and remove. What size oil wrench is required?? And too, what about the drain plug? Is there a cover plate covering it and what is the bolt size?? Thanks for the info.
sounds hi too-i would think that they would charge labor rate per hour-$250 would be at least 2 and 1/2 hours labor for oil change. if it takes that long, let them do it. if not, try another dealer. i have found that the price for simple jobs (mount, balance and install winter tires) can vary by hundreds of dollars between dealers. try a few dealers
I would like to change the oil myself. That must sound strange, No one has responded that has changed their own oil. I know that cannot be with these outstanding machines.
Four drain places??
Originally Posted by 99firehawk
well you will need a 15mm for the case drain and a 19 mm for the tank drain,
bot are easy enough to find, if you want to drain the turbos they are an 8mm allen
the case drain is loacated on the drivers side of the case at the bottom where the 2 halve join, the tank drain is on the pass side abut 12 inchs towards the passenger side and 9 inchs towrad the front of the car (thats a guess I Dont have one here to mesasure)
the case will drain about 2 qts. the tank 7 and if you drain the turbos you will get about .1 qts from each
Thanks for feedback.......
I Drain them i would imagine most dont, its a little hard to get the seal rings for the oil sumps fo the turbos.
the oil pan.............turbos dont have oil pans there is the engine case and there is the ol tank which holds the majoirty of the oil
Some more "special stuff?"
This business of seal rings...when I called my 100 mile away Porsche dealer for what was needed to change the oil, they did not mention the seal rings. I guess I won't drain the turbos at 10K miles, but I will be sure the dealer-tech empties them with new seal rings for the mandatory 20K oil change. Lots of black art to these little tech-chores...what I hate most is doing some mechanical work, then needing something not anticipated and no way of getting the part because shops are closed on Sunday, etc. Thanks again for the info.
Incidentally, are the drain-plugs visible from underneath the tt or is there some kind of plate or spash-pan that needs removing??
well im trying to think, Ive only had to have 1 997tt (except for the rt12 but thats diffrent " in the air but im pretty confidant that its the same as a 996 tt and has no pan under the engine
Thanks for the reply. I've had nothing but M3s up to now which have underneath splash covers. I'll have my tt in the air to change the oil next week and with your info should have no problems.
TJ
do a search of the 996tt forums. here's some links you'll find helpful
996tt oil change (need to be member of renntech.org)
http://www.renntech.org/forums/index...=%2Boil+change
993tt - draining turbos (and steps to remove) from factory service manual
https://rennlist.com/forums/993-turbo-forum/196641-factory-turbo-removal-proceedure.html
https://rennlist.com/forums/showthre...ght=oil+change
Super thread
Originally Posted by golfguy
TJ
https://rennlist.com/forums/showthread.php?t=196641
