Parrot 3100 bluetooth installed
I installed the Parrot 3100 Bluetooth device this weekend. Works relatively seamlessly with the stock TT PCM. When you make or answer a call the PCM is muted and reads "external phone active" on the PCM screen. Very happy with this sub $200 investment. I used info from BeckerAutosound.com, Parrot.biz forums, Rennlist forums to gather wiring and PCM removal info.
Have you updated your Parrot to the latest firmware? Instructions are here
http://www.parrot.biz/download/HTML_...e_%28En%29.htm
I use an A900 Samsung with Sprint and it does not support "object push" so I just use the phone's internal phonebook and voice dialing, which works just fine
