PCCB compatibility
I have tried looking it up but can't get a definite answer
Would PCCB brakes (rotors/calipers) from a 997.2 TT compatible with 997.1 TT?
The center lock option might throw this off but my research tells me, it should be OK?
- Nick
If coming from 350/350mm factory iron, Porsche does offer a cast bracket that was used on some turbo models to go from the 350mm iron disc to 380mm pccb disc (with 142->225mm spacing) and even the 380mm iron to 410mm pccb on the 991 Turbos. This accounted for both the bolt spacing and the larger disc diameter.
-Rick
HINZ MOTORSPORT
Race Parts & Accessories for your PORSCHE
www.HinzMotorsport.com
Call: 414-212-5679
Email: rick@hinzmotorsport.com
-Rick
HINZ MOTORSPORT
Call: 414-212-5679
Is your car iron or PCCB currently? The discs should be the same if PCCB, but the only issue may be in the .1 caliper mounting (142mm spacing) compared to the .2 caliper mount spacing, which may be 225mm. If you can confirm one way or another, that will help. I am not certain about either mounting dimensions, though. Both may be 142mm or one or the other. I realize this doesn't answer your question, but it's something else to consider. Iron cars had 350/350mm discs, PCCB were 380/350.
So .2 TT PCCB discs be compatible with both .1 & .2 TT PCCB Calipers & vice versa?
Are you sourcing used calipers and discs?
