Hope i'm doing the right thing?
Getting ready to sink some serious coin into "preventatives". Coolant pipes and cam pinning. No current issues 40,000+ miles and I just don't want to think about the possible "issues" anymore. While the motor is out most likely going to do full GT2 factory clutch set up with drilling the bell housing. Then add water pump, plugs, coils and all the other maintenance items and it will be a wallet buster bill.
You’ll forget about the money you spent in pretty short order, but you’ll enjoy the car forever more afterwards. I think you are doing the right thing if the risks associated with not doing these things weigh on you. You’ll be very happy you did it.
When I did a full rebuild On my 997tt, I did all of these items too, and it’s really nice not having to worry. Money well spent. I also did a similar thing with my old c6 z06... I was worried I’d drop a valve in the LS7 every time I drove it.... So within 3 months of ownership, I had the top end done and had the heads all done as preventative maintenance for peace of mind. Threw a cam in and ported the heads too as a bonus.
I’m still running the stock slave set up on a Protomotive twin disc clutch. If you end up going to the Gt2 set up, please keep us posted. Or PM me - I want to know your impressions.
I did all my own work and still spent about 5K in parts.. although I did pretty much replace every rubber part/hose external to the engine. Lots of piece of mind knowing it was done right.
Good luck.
9SIX4-C4 (03-16-2021)
I'd definitely agree with the GT2 clutch and coolant pipe pinning. Make sure you replace the plastic elbows as well.
Regarding the cams, my understanding (someone correct me if I'm wrong) is that there isn't really any cost savings to doing it preventatively vs after they've spun. If that's accurate, then I don't see any reason to spend money doing it when only a small percentage of cars ever suffer from that issue.
Thanks for that Nate. Im not worried about the cams because there is no chance of a catastrophic failure if one spins so its not like a water in the block issue. I was doing it because the engine will be out of the car. This can't be done with the engine in the car, right? I really don't know.
Nate Tempest (03-16-2021)
I agree about doing these things to the engine now. At 13 years of age, investing money to prevent issues that, in some cases, are only a matter of time is prudent. As mentioned, I would add every rubber hose and o ring to your list of items while the engine is out, simply because the engine is out. Why spend the money to drop the engine twice?
I cannot agree more about replacing the clutch slave. I cannot tell you how embarrassed I felt either over revving or stalling the thing before doing the GT2 slave. I have been driving sticks since 1976, and never have a had such a difficult time because of such an inconsistent clutch. Major benefit to the car, in my opinion. Make sure they check the clutch fork clearance on the bell housing. I have read instances where it rubs though mine did not.
Cam pinning can only be done with the engine out, so getting it done now also makes perfect sense.
You are absolutely doing the right thing, especially if you are like me and going to keep the car for a long time (forever in my case).
Ed
Ed
Ed
Ed
Wish you the best of luck with your preventive maintenance strato58. I wouldn't do it but that's just me.
When I read the title I thought you were considering selling, so many of the old time owners have gone and feared you were 'moving on' too. So happy to read you are going to invest instead!
After 14 years of owning the 997 turbo I still love my car and still find it the prettiest model Porsche ever made. Add Mezger and manual and it makes the perfect Porsche for me.
I am keeping mine till the end of time
LOMartin (03-19-2021)
