PCCB wear @ 23K
PCCB wear @ 23K
I thought that I would report my findings whilst contemplating changing my pads...
My car is a 2010 TT MT cab with 23K mileage... I've owned the car since 12.5K. It has never been tracked (during my stewardship) and I really don't hammer on it too hard plus I'm pretty good at momentum management and using the transmission. The car is equipped with torque vectoring and sport ++.
I had heard all of the forum stories that you need to replace the pads at 50% .... So I was looking for a COVID project and decided ordered a complete set from Suncoast $900.
After getting the car up on my rack and removing all the wheels.. these are the numbers that I measured with my trusty digital vernier caliper:
The service manual says to replace pads with 2mm left on the backing.... that would be way to thin for my taste but at this point, I could see getting more than 50K in mileage with my typical driving.
One thing of note is that I did find small little pebbles between the caliper and pad backing but I don't think it would have much effect.
Needless to say I didn't replace the pads but I did polish up my rotor caps with aluminum metal polish... they really shined up!
Any comments or thoughts for conversation would be interesting.
- front pads from SunCoast measured 10.5mm new (this is only the braking material not including the metal backing)
- usage of right front pads on my car top of caliper: outside 9.47 / inside 9.98 bottom of caliper: outside 8.98 / inside 10.07 (I didn't measure the left front of the car)
- rear pads from SunCoast measured 11.2mm new
- usage of right rear pads on my car top of caliper; outside 9.83 / inside 10.14 bottom of caliper: outside 10.7 / inside 10.52 (left rear Top outside 9.9 / inside 10.15 bottom: outside 10.56/ inside 10.07)
Replaced my front pads at 89K because they were at 55%.
Dealer said the rotors at 114K were showing virtually no wear and good for the life of the car. I didn't believe the no wear, but we'll see.
cyclrder (10-19-2020)
The following 2 users liked this post by Carlos4S:
cyclrder (10-19-2020),
Viper pilot (10-29-2020)
I have to say, I'll never have another Merc or Pcar without them going forward... I'm sooo over the brake dust on my E63 wagon and I even replaced to OEM with Porterfield RS4 pads that actually cut down the dust significantly, but they still leave a rusty brown coating that is a bitch to get off...
The following 2 users liked this post by Needsdecaf:
cyclrder (10-20-2020),
R1stcarrera (11-07-2020)
Replaced my rears last year at 43K.
They were around 50%
Not sure why they were that low so soon. PO may have had some track days.
I havent owned the car since new, but wasnt taking a chance..
that is actually about what I would expect. Remember that the PASM and Torque Vectoring are applying pressure even under normal conditions.
cyclrder (10-29-2020)
