Question on Frozen Rotors?
Has anybody tried these? I track my car and my PFC pads are pretty harsh on the stock rotors. Even after a few track days, already developing blue hot spots. Trying to look for a better rotor option, let me know your thoughts. Their website is frozenrotors.com
Originally Posted by Flewis763
Are you running drilled or slotted rotors. Guessing you are running drilled. Chancing to sebro slotted eith help that alot. Also made change to gt2 fromt ducts.
Ya unless tracking constantly, sebro slotted rotors are really your best bet. Drilled rotors crack easier as well as got spot and wave pads. Slotted is what you want if you are tracking your car.
How different/more effective are the GT2 ducts? Are you running front and rear?
Yeah. I just saw that. I may start with the GT3 ones and see how that works. From what I've read the GT2 ones might also require some custom cutting into the wheel well plastic.
Your biggest problem is the drilled rotors. Changing to slotted is a huge help.
Honeslty unless you are tracking the car 90+% of the time, slotted rotors, track pads, high temp fluid, and gt3 front ducts are all you'll ever need to keep temps in check.
Sebro slotted is what I typically run and suggest all my customers run. Best bang for the buck and last a long time.
Not when I spun into a turn and came to a stop after heavy braking at the end of a straight...
Typically frying the rear brakes is due to guys running with psm on on track and the TC fries the rears. If that's not the cause then you may need to add the gt3 rear rear ducts for more cooling. They are kinda fragile though. I planned on making some more sturdy ones out of alum in the future but have not got to it yet.
