Big Power Turbo Guys
No shrouds on those ICs?
Stock header configuration? Do you have any pics of the drivers side turbo from the other side of it? I'm curious how you routed your lines. I see you were able to fit the turbo without modifying the hanger bracket. I had to change mine.
I picked up a speedtech 3" and am fitting it to my Xonas this weekend. Should have the car out soon and can let you know whether there is unbearable drone.
There is a similar local car built at my preffered shop with the UI exhaust and it apparently has no drone. It shouldn't with the resonators. Getting one is a challenge.
