Question about starting with a manual
I have an Autoblip installed in my car. Today while out for a morning run the Autoblip stopped working and reported (via indicator light) that my clutch was continuously engaged. I thought maybe something was wrong with the Autoblip so I checked the voltages. The bottom clutch sensor circuit was reading zero volts and not changing when I depressed the clutch, so it seemed the Autoblip was not the issue.
I then tried to start my car in neutral without the clutch depressed and it started right up. Is this normal? Do you normally need to have the clutch depressed to start? Seems my car is reporting the clutch is engaged? Seems weird the switch would fail and still let me start the car...
Yes the clutch normally needs to be in to start the car, so it appears your switch has failed such that it shows the clutch always pressed (disengaged).
Glad everything is working and I had never heard of this product, looks pretty cool.
I know it's fixed, but just for others reviewing the thread.... The clutch switches are *continuity* switch, normally open, closed when clutch in.
Check the switch by looking at resistance, not voltage.
Be careful what you wish for. We had a rental car many years back and wife takes keys to go out to car and get it warmed up from the passenger seat. Car was left in gear and when she turned the key, the car lurched into a 4" steel pole..... $2000 later. Sigh.....
I did this at 17 years old. My Dad has a 300zx. Manual.
Cleaned it up for a date and went out to start it by leaning in the window. Turned the key not knowing he left it in gear. Right through the garage up to the drivers mirror.
Lesson learned. It’s funny looking back but at the time terrifying.
