Calling all Aerokit wing owners of past or present
Thanks Johnny
i originally purchased an oem aerokit from design911 for around 4900$ shipped, of course once the deck became NLA that changed. Their kit consists of a 1:1 cloned copy of an oem deck in fiberglass cmpd, oem skirts/ lip/ rear valence (oem aerokit paintable fiberglass components ). I paid around 2900 shipped. You still need to purchase the wire harness, ram edge, seal, rubber bumpers. The deck is pretty spot on, accepts all oem components, etc. I had to drill holes for the two airbox rivers and the bumpers, everything else is ready to go. It needed very little work to look ok, but a lot to look perfect, it’s fiberglass. The oem parts also needed a lot of prep work. It’s pretty much an exact copy, everything bolts up, I’d give it an 8.5/10 only because I had to drill holes. Installation was easy, the rear valence was the hardest by far. The brake and inner light could fit a little tighter, I used a little silicone so it wouldn’t rattle, probably would’ve been fine.
i suspect the deck is the same part as the NR Auto version, theirs is 3k painted, my deck was about 980 plus work, it’s a wash. If you want an oem aerokit this is your best solution but it does need some work, I looked on and off for an oem
deck for 10 years, only a few ever popped up.
i drove it today, totally stable over 100mph (Mexico). I had a chance to compare it side by side with an oem, it was essentially identical.
Hope that helps anybody on the fence.
c
Thanks Johnny
i originally purchased an oem aerokit from design911 for around 4900$ shipped, of course once the deck became NLA that changed. Their kit consists of a 1:1 cloned copy of an oem deck in fiberglass cmpd, oem skirts/ lip/ rear valence (oem paintable fiberglass). I paid around 2900 shipped. You still need to purchase the wire harness, ram edge, seal, rubber bumpers. The deck is pretty spot on, accepts all oem components, etc. I had to drill holes for the two airbox rivers and the bumpers, everything else is ready to go. It needed very little work to look ok, but a lot to look perfect, it’s fiberglass. The oem parts also needed a lot of prep work. It’s pretty much an exact copy, everything bolts up, I’d give it an 8.5/10 only because I had to drill holes. Installation was easy, the rear valence was the hardest by far. The brake and inner light could fit a little tighter, I used a little silicone so it wouldn’t rattle, probably would’ve been fine.
i drive it today, totally stable over 100mph (Mexico). I had a chance to compare it side by side with an oem, it was essentially identical.
c
Everyone. I'm next and my wing is scheduled to arrive tomorrow. It's been great to have Chris walk me through everything so I know what to expect and what parts were needed. I also have been on the hunt for the factory deck lid and could have bought one off a wrecked car L.A. Dismantler for around $3500 and would have still had to re-paint etc....And then one came available for about a minute which by that time I was not looking as intently. I'll post pictures when done.
On a side note, the car came to me with the sills already painted. I had the rear valance painted in 2017 when I did the .2 rear bumper conversion. At that same time I bought a front lip Aerokit clone from Amazon for cheap in PU. Had that painted and so far so good on all of them.
Regards
Tim
snolvr (06-06-2022)
The oem aerokit consists of painted skirts, front lip, rear valence and the aerodeck lid. The design 911 kit is all oem except for the deck which is a very good fiberglass copy. 1:1 clone of the original. All these pieces are fg and require finishing. Fit and finish pretty good. You will still need the oem ram edge, harness, seal, bumpers
if you want an oem aero this is probably the best option unless you find a used one. Nrauto and icar also make one, no idea about it
c
c
c
c
RennKit-Dave (12-14-2019)
