Bilstein B8s
Bilstein B8s
New to the group and looking for opinions. I have a 997.2TT that's that sits too low (Champion springs) and looking to swap them out to Eibach (seems to lower the car the least amount, 0.8"). Is it worth replacing the dampers with Bilstein B8s? Car has < 25k miles. Since the labor is pretty much the same with a spring swap, I'm debating if its worth forking the extra $ for new dampers now or just ride out the OEM dampers until they die. I dont really intend to track it and probably occasional mountain driving, so I'm passing on coil overs. Plus I dont think i'll ever care to change the ride heigh (lower it anymore). I've read that the B8s were designed for lowered springs. Any one running this setup? Thanks.
The things worth the most when it comes to improving the car's drivability are tires and springs/shocks. Next would be sway bars and bushings although you will increase stiffness and NVH (noise, vibration, harshness) with each change you make away from the OEM setup.
RockyTop (02-01-2022)
I have B8s and have posted a few times. Worth it IMO - but might be hard to find - search "perpetual back order" in this forum.
I have GMG and drop is good, not too low. Eibach may be same don't know
