Advice Needed: Turbo Leaking Coolant
Hi All,
Before I tear the car apart, wanted to run this by someone. I have a small coolant leak on the passenger side turbo. I determined it's coolant due to the color of the fluid. I say it's small because when sitting parked, it only develops a few drops a day. A bigger puddle of coolant occurs when the car is parked after a drive and when it's cooling down. Doesn't seem to drip while running, weird.
I'm confident that the leak is coming from the coolant inlet or outlet pipes going to the turbo. I don't think the leak is coming from anywhere above the turbo, all dry up there. The advice I'm seeking is what is the best way to remove the coolant inlet and outlet pipes going to the turbo? I want to get in there to check and replace the o-rings. I found and contacted a forum member that had the same issue on another thread (link here). He just pried them off resulting in bending the pipes a little. Hesitant to do this because the coolant pipes are metal and afraid to damage it. This the best way to go about it?
I believe the coolant inlet pipe is #2, and the coolant outlet pipe is #3. Is #1 the oil supply line?
Thanks in advance.
Thanks in advance.
I'd get a borescope in there after a hoon and verify 100% that it's coming from where you suspect before doing anything.
Can't give any advice on removing pipes, sorry about that. Am sure someone here can though as I assume you need to when removing the turbos.
best way to get those lines off with out bending them is to remove the turbo, replace the o rings and reinstall.
removing the turbo is not a hard job. just takes some time in you have never done it before
Where are you located?
thanks for the advice, I’ll try and see if I can borrow a borescope from someone. Just confident it’s coming from the turbo because I don’t see any other place coolant can be leaking from.
i did consider removing the turbos but never done it before. Located in Northern California. Anything special I need to know before removing turbos? I also told myself if turbos need to come out, I’m upgrading them, heh.
I'm pretty confident it's leaking from the coolant o-ring as it's the same exact symptoms as was mine. I agree, if the turbo is coming out, I would consider upgrading as well.
Either way, it was a lot of work to replace a $2 part. You may want to replace plugs and coil at the same time if it's due.
if you need the step by step just let me know
Upgrading turbos so tempting since i'm this far in it already.
Went ahead and tried removing the coolant and oil lines without removing the turbo, and it was fine. There is actually some flexibility in the lines although they are metal. I was initially afraid of bending them, but there is definitely some play in them.
As suspected, the o-rings were brittle. After removal, they were discolored. O-rings are typically black, they were green in color. When prying them off, they did not come out in one piece. Instead, they tore apart. Compare to the o-rings from the oil lines which are black in color, still flexible, and came out in one piece. I have o-rings on order from the local Porsche dealership, should be here next week.
During the removal of the coolant lines, lost some coolant. Will have to add more. Anyone know how to bleed or burp the system? My next concern is getting all the air out of the system. After searching a bit, it looks like the easiest way is to maybe just run the engine until the radiator fan kicks on and open the breather valve (which I'm still trying to figure out)?
Thanks.
coolant lines out
discolored and brittle o-rings
coolant orings tore apart, oil o-rings still soft (the 2 right most)
Thanks.
coolant lines out
still searching for proper way to bleed or burp coolant system though.
thanks
