Diverter Valve Failures
Hi Gents...My Turbo build is complete. Had some delays for the past several weeks chasing vacuum leak issues (real or perceived) during the tune process and then things really went sideways when the RPM would marginally increase when the throttle was released. This issue was eventually diagnosed as failing diverter valves (new Forged diverter valves had been installed as part of the build) and the OEM DV's were reinstalled and Walla! All problems disappeared and the heretofore drivability/throttle application issues were also resolved.
Just curious if anyone else has experienced DV failures and if so what your symptoms were (I am kind of kicking myself as I was the person who requested the Forged DV's when we put the build list together). My car is being shipped back Thursday and I am really looking forward to some seat time. |
Everything I've read is that the stock DVs work well and there is no reason to change them. Maybe if you are going for a much bigger build they make sense. Didn't you upgrade your turbos, too? Which ones did you get?
Kinda like headers, most everyone says the stock ones are pretty darn good unless you get into the 800+ or more HP builds.. |
Originally Posted by usrodeo4
(Post 15505195)
Just curious if anyone else has experienced DV failures and if so what your symptoms were (I am kind of kicking myself as I was the person who requested the Forged DV's when we put the build list together). My car is being shipped back Thursday and I am really looking forward to some seat time. when were your leaks apparent? idle? |
The Forge pistons ones can cause all sorts of issues. They can get stuck in the cold weather, jam up in hot weather/temps, leak from the o-rings twisting around. I have always just run stock diaphragm style ones without issue.
Originally Posted by saabin
(Post 15505358)
Originally Posted by Turboslut
(Post 15505519)
(Post 15505716)
We had 3 or 4 leaks identified; some manifested themselves with rough idle and one was mid rpm ~4k rough throttle, then the last issue was RPM increase after the Go pedal was released. The leaks were throttle body hose, o ring in one of the diverter valves, a bolt screwed too far in one of the intercoolers that caused a loss of pressure and possibly a fuel regulator hose. Sam at ByDesign felt the failing diverter valves may have been contributing factors all along as once they were replaced with OEM DV's even his base tunes were almost perfect. The silver lining to the cloud is the car was thoroughly pressure tested multiple times.
Oh trust me....I have been dealing with a "leak" of some damn sort for months now. Ordering my oem valves now. |
Agree, I previously used Forge DV's and returned to stock. OEM's are plastic whereas Forge are metal. IMO that's the only difference and contrary to popular belief they do not increase horsepower.
Originally Posted by 4ocious
(Post 15508495)
Rodeo, can you share which codes were present in your car?
Where did you order the Tial VTGs from? And did you upgrade your injectors also?
(Post 15508495)
I also found part which is goes from back of the plenum...and then tees off to the AIR injection system and also controls the diverter valves. I wonder if when faulty is also causes leaks. 9A1-605-165-00It is cheap enough to replace....so i think Io am going to replace as well.I keep getting P2187 and P2189 CONSISTENTLY....but it is intermittent. Sometimes car is horrible to drive and others it is fine. Luck of the draw when it starts up....so it has to be some sort of valve failure (electrical at that). |
Originally Posted by USNA12
(Post 15509695)
(Post 15509533)
The last drivability problem that was so vexing that was fixed by installing the OEM DV's was not throwing a code.
