Pentosin Reservoir Belching Fluid
I cannot figure this out and its driving me crazy... Bought the car last autumn (2007 manual TT).
My clear pentosin reservoir (with green lid, in boot under plastic trim) continues to belch fluid. I bought a new lid, so I know it is tight. It will squirt through the relief hole in lid. Enough leaks that I see drops on the garage floor.
My mechanic checked it out this spring and did not notice a problem with hydraulic system operation.What would cause this?
Agree, from what I have read this is the classic symptom of the factory hydraulic assist clutch failing. You should be able to search for that issue and see some information about it. You will also see several options for solving it, although the path you take will be based on your personal preferences.
Ed
Ed
Maybe not, one symptom of a bad accumulator is (in addition to other things) a very stiff clutch pedal when the car is off.. Notmally when you shut it off you can push the clutch in a bunch of times befroe pedal effort increases. With a bad accumulator it takes like 1 or 2 times to get stiff.
If it's pumping out of the front, your rear area is probably dropping dangerously low. Have you checked the area in the engine where you put in pentosin? I had this happen to me a few months ago. It was a faulty slave and had to be replaced. Everything's fine now.
+ 997 on accumulator failure.
Into the shop next week. I am told this can be an engine out event. Will post results.
Clean up - soak affected area with Simple Green, rinse, repeat? Area is SUPER tight.
I've never heard of anyone just doing the slave. Most do slave + accumulator. The parts cost is nominal.
Personally, i've done it 3 times on two different mezgers, i.e. slave & accum. and its NOT engine out
