997 Turbo Forum 2005-2012
Ball Bearing Vs. Journal Bearing
Old 09-13-2018, 01:26 PM
usrodeo4
usrodeo4's Avatar
Originally Posted by 32krazy!
ill take my borg warner efr ball bearing turbos any day. oil AND water cooled. good enough for the indy car series good enough for me huge spool down low and handles 1100 hp. best of all worlds
I concur...
Old 09-13-2018, 03:52 PM
32krazy!
32krazy!'s Avatar
Originally Posted by lliejk
Looking at those BW turbos, I had to sit down and process spending $9K for two of them. I was trying to justify $1500 - $2K for 1 turbo on a UrS6, so this would be quite the stretch (for me at least).
Ed
twin efr 7163 turbos are less than 5k$ with oem exhaust hot side flanges and water lines. the 6258 turbos are slightly less. keep in mind the efr turbos have intenal wastegates that can handle 35 psi and theres a built in bov the recircultaes the air to the compressor whjeel to keep spool up during shifts. this save you 1000$ in external parts
Old 09-19-2018, 01:14 AM
911.Forever
911.Forever's Avatar
Appreciate the write-up, thank-you :-)
Old 09-23-2018, 08:22 PM
J'sWorld
J'sWorld's Avatar
Coming over from the Cayenne forum because we are looking to get into a 997.1. I put the efr 7163's on my Cayenne build and they are really impressive! Time will tell how they hold up but they sure are light with the aluminum supercore and even though we have just started tuning I couldn't be happier. The built in CBV's are working perfectly and eliminate a lot of plumbing that I don't have room for and two aftermarket valves.
I know adapting them to the 997 is a bit different if you want to use the exhaust housing but FWIW I paid $ 1090 each for the supercores on a Jeg's price match, ~$300 each for the turbine housings, and another $290 each for the 90 degree forward facing compressor covers, which ended up being free after I ebay'd the originals. I don't think there is another turbo of this size that you can get with a 2 1/2" inlet that doesn't surge or shuffle.
https://rennlist.com/forums/cayenne-...fr-7163-s.html
Old 09-24-2018, 04:50 PM
32krazy!
32krazy!'s Avatar
the engine builder i use has new hot side housings that are a direct bolt on for the 996tt and 997.1 turbos. you use oem headers and exhaust flanges for a plug and play install.
Old 09-24-2018, 06:52 PM
J'sWorld
J'sWorld's Avatar
Nice, that makes a big difference for the little guys.
Old 09-24-2018, 06:54 PM
J'sWorld
J'sWorld's Avatar
I'm not so sure the journal bearing designs have the long term thrust capabilities of the BB type and the spool is not arguable between the two.
Quick Reply: Ball Bearing Vs. Journal Bearing
