Over rev report with icarscan?
Anyone been able to pull the dme rev report/time counter etc with the icarscan? Played with mine today and couldn’t find where to get that info if possible.
anyone try the Foxwell NT520? They claim it's the new and improved NT510, only $10 more on ebay.,,
[QUOTE=pfbz;15261770]anyone try the Foxwell NT520? They claim it's the new and improved NT510, only $10 more on ebay.,,
Just received this item today from the same seller and so far, I'm impressed. I'm able to read the DME over revs info, activate the ABS pump, get into custom customer programming options like changing side markers to flashers, etc. I'm not able to test the Oil Maintenance light as mine is currently off (recently reset with iCarsoft) and when I tried to reset again, I get a function not supported message. I also see an option to reset airbag light but have not tried it (don't plan to as the light is off).
[QUOTE=atm4jim;15271645]
What other coding can you do with the Foxwell unit?? Do you think it will be able to disable TPMS, activate the CD changer, etc.?
I have a durametric already, but I definitely prefer a stand-alone device than having to grab a laptop, boot up the windoze emulator, make sure the drivers connect properly, etc...
I also like that the Foxwell can evidently be loaded with software packages additional brands for I think $70 each? Need an Audi tool as well for the wife's Q5.
[QUOTE=TypeRx;15271970]
It seems possible, found the following menu options below that you should be able to set as installed or not. Though I haven't tested it and don't want the risk in trying.
I think I will order one of these and, if happy with it, sell my Durametric enthusiast.
*Edit* Just bought a Foxwell NT520. Will report back late next week after I receive and have a chance to play with it. First order of business is disabling the TPMS.
Massive thumbs up for looking into it!!
Ok, received the NT520 a couple days ago but finally had an opportunity to try it out today. I also have a Durametric Enthusiast. On a positive note, the NT520 appears to provide everything the Durametric Enthusiast does in a standalone package and at a lower price. Not everyone may trust a "Chinese" interface hooking into their car's systems but it seemed to work fine overall.
In addition to reading codes, over-revs, etc., I was able to code my seat belt chimes off as well as making the passenger window one-touch up ("comfort"). I am also planning on calibrating my steering sensors in the future. Unfortunately, I wasn't able to turn off my "Service Now" warning. I also was not able to access the TPM to disable the TPMS system. In both cases, I received a "selected function is not supported" message. WTF. I may need to play with TPM a bit more as the post a few up appears to show an "edit" option next to TPM being installed -- but that definitely wasn't the case in the coding section. And, it still doesn't fix the inability to turn off the service message. I read some where having trouble with this on the 997.2 but I have a 997.1TT.
I think one of the challenges is knowing which sub-menu to access everything. In some cases, you go through the diagnosis menu and can code from there but in most cases you need to code from the coding menu. A full directory would be helpful as I spent a solid hour just going through every function. I wish I documented things.
Bottom line, for $160 it is a great value, but still not perfect (not to be expected anyways). I also like that you can add on another mfg. module on to the unit for $70. I also have a VCDS (Audi/VW) interface that is glitchy and requires a separate computer/emulator. It would be nice to consolidate everything, so that is something I'll look at doing in the future.
If anyone has any feedback or tips, please share away!
Oh, and one other thing. I went to the Foxwell registration site to register my unit but noticed that it is not a secure site. No thanks -- not putting my name, email address, and setting a password on a non-secure website. Not sure how that even happens in this day and age....
