Power Window issues fault code 8026
Hi,
Both windows are acting weird since my battery went flat. The auto down up is inop on both sides, as is the auto close after shutting the doors to ensure watertight door seal.
I reset all codes with my durametric cable, but cannot get rid of code 8026 on both doors.
I also tried the reset procedure by closing both doors and holding the up botton, releasing, and then holding it for a 5 sec count.
Then I cleared all codes and it wont go away... Any ideas
TIA
TIA
TIA
TIA
My passenger side window acts a bit funky as well. Auto down is fine, auto up doesn't work, nor does holding it up manually. It just goes back down again. I connected with the original owner and he said it's always been quirky. But I don't have fault codes.
I recall reading something about a dealer having to reset the car after swapping a battery. Maybe this has something to do with it?
I'm long out of warranty, and haven't run a stock battery for years. Its gotta be programming related as both windows started doing it simultaneously
Update:
I have tried all of the above:
-disconnecting battery for 10m
-disconnecting battery with windows down 1/2 way for 10m
-tried reset procedure (close windows with doors up). Then tap and hold button while window is up to confirm upmost position.
-cleared all codes with Durametric (multiple times)
-I've also made several prayers to the Porsche gods, and am considering a sayonce next.
I cannot clear code 8026 from either door.
help!
help!
Basic Sponsor
It has to be something to do with the ECU relearning, since they worked fine before the battery drain. You may have to pay a dealer to PIWIS on it, but don’t count on the fix being permanent, I just have a feeling.
Dave
Rennkit
djcooper@rennkit.com
http://rennkit.com/
Rennkit
http://rennkit.com/
- Patented eRam Kit™ for 996/997 Turbo & Carrera GT wings
- Cal*Cool™ - brake cooling 996/997 / Bluetooth Retrofit Kit™ for 1998-2011 cars / Wing Extenders™ 987 Cayman / 997 Turbo
- AUTO-BLiP for MT / Function F1RST Shift ***** / Girodisc 2-piece rotors / OS Giken LSD / Phenix suspension / Zunsport grills / 997/987 switches/PCM ***** / Border Coilovers
I'm gonna try my indy mechanic.. believe he has one. I have to go there anyway do the other issue I posted above.
Hi, what was the solution to this problem, as I have exactly the same and have done the same as you have tried but no joy.
Hi,
TIA
TIA
TIA
TIA
