I hear this is a big no-no
Received 2,010 Likes
Worthless....But I'll buy it!!
Things that are being repaired:
-Passenger A- pillar material adhesive is peeling. It appears in its previous ownership someone cut major corners and the cheap job cannot stand up to the texas heat.
-Front dash leather trim is peeling back from the windscreen, looks to have not been maintained well. I knew it was an issue when I bought the car and I tried to recondition the leather, no dice.
-Both Maf sensors need to be replaced + replace the tech art air filter with a OE filter
-Ohlins road and tack will be going on the car
-At John's recommendation from autoquest (Thanks again John!) I'll be putting on slotted rotors and ferodo ds2500 pad's on the car
After that it will be quite literally 100%
A good UV blocking window tint is a must! It will save your dash and leather....and keep the heat out.
http://www.llumar.com/automotive-fil...le-window-tint
I am enjoying every mile.
After the 600 miles trip I am about to take this weekend I may be hitting 70k
I bought it last September with 60.5k miles. I have my truck I use for work, and 2 motorcycles I use on sunny days. I have no idea how I accrued so many miles in this beast but I am ok with it
