Rear deck wing really necessary?
my 09 wing recently became uneven R to L. As much as I love the functionality of the wing I took it to a local custom P shop and they fixed the wing in a raised position approx 1.5in above the base setting. They removed the pump, drained the system to prevent future leaks and set the code to a fixed wing GT2 so i do not get any warnings. car looks good and I have some room to clean under the wing. Total cost ~$450.
Very very important above 100 mph on the track
For street driving no issue
go wingless
go wingless
Basic Sponsor
Dave
Rennkit
djcooper@rennkit.com
http://rennkit.com/
Rennkit
http://rennkit.com/
- Patented eRam Kit™ for 996/997 Turbo & Carrera GT wings
- Cal*Cool™ - brake cooling 996/997 / Bluetooth Retrofit Kit™ for 1998-2011 cars / Wing Extenders™ 987 Cayman / 997 Turbo
- AUTO-BLiP for MT / Function F1RST Shift ***** / Girodisc 2-piece rotors / OS Giken LSD / Phenix suspension / Zunsport grills / 997/987 switches/PCM ***** / Border Coilovers
So, after reading about complaints of the looks when the wing extends at speed, and the cost of replacement of the hydraulic wing parts on the turbo rear deck, I'm wondering if this is really necessary (functionally speaking, under 150MPH). The carreras only have the small wing that lifts up a little. The turbos are over 100 pounds heavier than a carrera. So, why can't you just replace the turbo deck lid with a carrera deck lid?
http://ebwerks.com/models-996997.html
I think as the speeds of 911's continued to rise, just reducing lift using the spoiler was not enough and they had to go to the airfoil that rises at 75 mph. If you really look at the design of the top portion, the airfoil, it's an inverted airplane wing. Thick at the front, thin at the rear, flat on top and sloping underneath. I actually took the time to look at the shape of the raised portion (really bored one day). So instead of creating lift as is the case with an airplane, it produces downforce. Even the tips are turned downward on the Porsche airfoil, just like the tips of modern airplane wings are turned up to make the wing more efficient. The tips reduce the amount of air from vortices from spilling back over and hurting the lift; or for the Porsche, from reducing available downforce.
Nice view of the wing design here:
https://www.bing.com/images/search?q...lift&FORM=IGRE
You also might find this tech discussion interesting. It's an old discussion on even older Porsches, but I found the technical discussion and photos starting around post #13 pretty good. Again the basic shape is unchanged, meaning so are the physics that underly the design. On the older Porsches, we even got into discussion of the impact of the rear spoiler on engine temperature, back when they were air cooled. Not nearly the issue with the water cooled engines if at all.
http://forums.pelicanparts.com/porsc...irst-then.html
These are definitely just my opinions, I'm an EE and by no means an aerodynamics engineer.
Good stuff! A bit more about the turbo wing evolution HERE.
Also, I had not looked at that old Pelican writeup for about 8 years. I recalled that discussion so I attached it. It's striking how the bottom portion of the spoiler/airfoil setup on the 996/997 turbos is so similar to the duck tail of the earlier Porsches. They just added the airfoil for additional downforce.
I think what the OP would like is a 993 style operation for a TT, but I'm sure it's nowwhere as functional as the current TT design. It's functional while maintaing the classic 911 lines most of the time. On the other hand, the 993 doesn't have the same top end potential as a 997TT so it doesn't have to be as efficient.
https://www.bing.com/videos/search?q...0BE3&FORM=VIRE
Curious to know if any other TT owners has removed the wing and replaced with a Duck tail? I also think the wing ruins the beautiful hips from the rear angle and the shape of the rear.
I like the ducktail on 997s. I think it flows well with the wide hips. Would I do it? Not for the look I’m going.
Is there a fixed wing kit out there, if the system failed and you just don't want to deal with it? Where it raises the wing a little like poster's above, and let it be once coded out.
Edit: I answered my own question, just buy Rennkit extenders:
https://rennkit.com/product-info/997turbo/
RennKit-Dave (06-25-2023)
