Engine removal
Engine removal
I have to have my engine pulled on 2008 911 Turbo 39,000 miles. The plastic pipes on the water manifold need to be replaced. What other items should I consider replacing while the engine is out? Spark pugs etc. Also should I consider going to steel pipes on the water manifold?
Pretty thorough thread here:
https://www.6speedonline.com/forums/...motor-out.html
I'm sure you won't need to do everything mentioned there but it's the laundry list.
