09 TT Lumbar Air fill
This might be a first. Any advice is appreciated. Every time i shut the car off the lower back of my drivers seat fills with air, seems like to the point its about to explode. and every time i get back int he car i have to deflate it. Yes this happens with the key out and the engine off. I'm perplexed. Also yes i tried to save the seat position in memory for all 3 settings with the seat deflated, just in case there's an entry/exit seat setting, which i also couldn't find in the menus using the center stalk.
Any tricks, advice, solutions, or just pointing out the obvious stupid thing im missing woul dbe greatly appreciated. thanks |
It's likely damage to the wiring underneath the seat. When I first bought my car this happened - had someone look at it and the wiring had been slightly damage at some point. Resealed it and it went away 99% of the time. It happens once or twice per year when I turn the car on but most of the time it doesn't.
Thanks for this suggestion. I will have a look under the seat.
My 2009 does the same thing i reset om memory for Key #1 and so far it has not happened again. But I also just had a new key coded to the #2 last week maybe that is the reason it is not inflating by itself?:confused:
I might try my other key. Thanks for chiming in
Seat module |
