View Poll Results: Have you had a coolant pipe failure on your 997.1TT
Yes, I had a coolant pipe failure on my 997TT
43
27.74%
No, I've not had a coolant pipe failure on my 997TT
94
60.65%
No, I've not had a coolant pipe failure, but I preventatively addressed the issue
18
11.61%
Voters: 155. You may not vote on this poll
997.1TT Coolant Pipe Failure Poll
#63
2007 no issues...yet. Reading this forum makes me worry about the coolant leaks and a spun camshaft every damn time I use it. For that reason I don't ever feel like I have piece of mind. All that and i've had absolutely zero issues with my car to date.
#64
I agree - after reading these forums, and being a critical engineer, I'm always checking under the car to see if anything is leaking. It is a curse - but I still enjoy the car. Honestly, sometimes it feels like it is best to stay away from forums - ignorance is bliss, right?
#65
And stay away from the dentist in case they find a cavity...
Just drive and enjoy, don't sweat the small stuff, we only live once.
#66
Yes I have had an issue with the glue giving way with age. Mine was a pre owned 2007 car which was hardly used. And when i did start using it, one fine day it gave way. While doing the reglueing and pinning, i asked the PORSCHE guys to scope the bore. It had developed scoring marks which were bad. I had to redo the engine. Undergoing installation as i write. Should be up and ready in few days. My suggestion is to pin the aluminium outlets if you have the engine out, to avoid a situation like mine.
#67
To look at our data critically, it looks like failure rates are 25%. This is rife with issues. The first impacting factor is forum participation, which probably reflects a more engaged enthusiast group. Usage factors are of course, a variable that's unquantifiable.
I suppose I'll preventatively address the issue next year. Until then, here's a picture from today. A December 18th drive in Michigan is a very rare treat! After a fresh oil change to Amsoil 0W-40 for colder weather, a drive hits the spot.
#69
No issue here. July 2008 build.
Side note, my 2002 turbo, which i owned for 5 years and up to 65,000 miles never suffered the issue either.
#70
#71
On my 997.1 07 Turbo I found a pipe backed out about half way at 34,500 so I had all the pipes pinned and hoses replaced.
I also track a 04 GT3 so I already dealt with the issue in that car and was on the look out for the issue in the Turbo.
#72
My 996 has 68k miles and still all original, however dropping it in Jan/Feb to do the fittings. The 997 has 52k miles and will be following right after the 996.
#73
Anyone in SE Michigan have their pipes done? If so, a shop recommendation and opinion on the repair is helpful. Pinning, re-epoxy, knurling, welding...not sure what's best.
#74
#75
Bumping this to gather some more data.
Happy Memorial Day to all those observing.
This car sparks, in me, great joy.
