New Porsche TT Owner Joys and Woes
Impressive numbers, RoscOtis. Never tried with my '08 Tip, but a question. What is the long term effect of each such launch, bullet proof as I am told my transmission is?
Another thing to note is tire pressure. I always keep 35-38lbs in my tires. My philosophy is lowering tire pressure will only increase traction and put more wear on the drive train. I don't have an issue if the car breaks the tires loose at hole shot (it rarely does when launched under 10 lbs boost).
It takes some getting used to but once you have a rhythm in place it becomes routine. I'm sure you've also heard the old saying "if your scared to break it don't race it!".
Hey Rosco, sorry about that, my comments were for Actbi5. I think your posts pretty much hit the nail on the head as far as these cars are concernend and your view matches mine, except for one small detail - you know how to race!
Ed
Ed
These cars are 10+ years old now. Things break, that's the way it is. When they break, fix them. It's a price we pay to enjoy such wicked automobiles. You seem to have a resentful attitude towards your car in many of your posts, have you thought about just selling your car and moving on to a different platform?
To the OP - great post, I enjoyed the read. These cars are a blast on the track and with the maintenance & repairs you've done you should be in good shape for a while. Enjoy the ownership of a 997TT!
Yes- OP- enjoy your new ride and welcome!!!
Nope, still in my climate controlled garage. No resentment I tell you. Actually ecstatic in the thousands and thousands of dollars saved doing my own work. Very very happy. No coolant smell here guys, all levels check!
^ Seems inconsistent to repeatedly proclaim in multiple posts these cars are ticking time-bombs, awaiting to explode at any moment and drain your wallet of thousands, all the while being "very happy"..
I guess its just me..
Thanks RoscOtis. If I try it, will save me some $$$ with the boost at 7 psi for launch. Would not have thought of that.
You misinformed dude. Hope it does not happen to you. Unfortunately it will to some extent. Don't know why you are so upset at me. I contribute positive statements. Some of the opinions are mine. I would not buy this model if I had to do it again. Don't know why you take this as resentful? Look at the post above? It will happen to you.
Fixing the coolant pipes should be a one time fix and you'll never deal with it again. It's virtually a no-charge fix if you consider doing it at the same time as a clutch change, or even if it fails - replace the clutch and justify to yourself that the cost for repair was to replace the clutch and you got the coolant pipes while you were in there. Then there is the spun cam issue, which is way less common but indeed a cost-intensive repair. The caveat though is that the cam pinning is a permanent solution - it will not recur after being properly addressed. Everything else is common stuff that would need to be serviced, repaired, replaced on any 10 year old car.
Life is short dude, don't waste time with a car that doesn't make you completely happy. Sell it for good money while the market is hot and jump into something newer, with a warranty, at the same price point. M4, C63S, etc...
Personally, I find threads like this very informative and appreciate the people who take the time to detail what they have been going thru.
I have had my 997.1tt for about two trouble-free years now and consider myself to be lucky I guess. I still have a lot to learn coming from the BMW community but I have to say being back in a Porsche has been nothing but rewarding so far. I plan to have my cooling pipes replaced and pinned with sharkwerks piping when that time comes. So far I have not had any issues with my OE cooling piping. As for the cams, I will deal with that when the time comes... not sure if I will do a preventive maintenance on this but then I might... I'm still figuring out the priorities for my car.
