997 Turbo Forum 2005-2012
DME - Not good news for me
Old 03-05-2018, 09:07 AM
triplenet
triplenet's Avatar
Default DME - Not good news for me
Well , had a potential buyer do a PPI and DME .... PPI came back fine but check out the DME ...
Granted I do track the car on occasion - but have never missed a gear nor beat it up out there...
The DME results are a shocker to me.... Sent some oil samples out and will do a compression check ...
  • - Range 4 – 1368 @ 1323.400 operating hours
  • - Range 5 – 189 @ 1298.300 operating hours
  • - Range 6 – 14 @ 1288.500 operating hours
Old 03-05-2018, 09:13 AM
LexVan
LexVan's Avatar
Received 5,388 Likes on 2,509 Posts
What are the current total operating hours?
Old 03-05-2018, 09:15 AM
triplenet
triplenet's Avatar
1405...... runs strong ... no issues ... hopefully oil and compression come back fine...
May just have to keep it for a while :-) .....
Old 03-05-2018, 10:14 AM
Skwerl
Skwerl's Avatar
Did you own it during that period?
Old 03-05-2018, 10:28 AM
triplenet
triplenet's Avatar
yes... Since it had 22k miles 3 years ago... now has 37k on clock...
There is absolutely no way I hit 9k rpm... I shift at most around 6 to 7k on the track and downshift sequentially thru the gears...
I expected a range 4.... the 5 & 6 are really odd ...
Old 03-05-2018, 11:20 AM
Tmistry
Tmistry's Avatar
Is there a chance of errors due to a tune? No idea on this, but it seems possible. Readings register higher for some reason? Seems you'd remember a 9,000 rpm shift.
Old 03-05-2018, 11:24 AM
Skwerl
Skwerl's Avatar
If those numbers are spurious (and I agree you should definitely remember a range 5/6 incident), then it's pretty alarming how unreliable a DME report can be. So many cars are branded a scarlet letter because of these reports.
newton982
newton982's Avatar
Could a rev to 9K in neutral generate a range 6? You could do a compression test which you could then pre-emptively provide to buyers. It would also give you peace of mind if you decide to keep the car.
Old 03-05-2018, 11:26 AM
TT Surgeon
TT Surgeon's Avatar
Tunes are notorious for f'ing up your DME report. If the car runs fine I wouldn't worry about it. The only downside for you is resale, I'd go thru the motions like youre doing to prove all is well then offer a small discount, ~5k or so. Last option is to just trade it in and let the dealer worry about it.
Old 03-05-2018, 12:17 PM
A418t81
A418t81's Avatar
These rev reports seem to be a bunch of total BS to me. Case in point: I logged my range 4 ignitions with durametric, went out and did a data-logged pull to 6980 rpm, and then relogged my range 4s. They went up. A verified pull to less than 7k rpm resulted in increased ignitions in the 7400-7900 range which my car has never touched.
Old 03-05-2018, 12:22 PM
Skwerl
Skwerl's Avatar
It would, but you can only get to range 6 by forcing it mechanically, like with a missed shift. (Or via computer glitch...) Revving in neutral should reach a rev limiter well below 9k.
And unfortunately, all the compression tests and Blackstone reports in the world won't convince some buyers that a car with range 4/5/6 revs isn't a beat up mule at death's door.
Old 03-05-2018, 06:40 PM
thxbuff2001
thxbuff2001's Avatar
Thats about 80 hrs from the last overrev. Most likely that engine is alright.
Old 03-05-2018, 06:51 PM
o7silverturbo
o7silverturbo's Avatar
Has anyone ever seen these reports actually true? Like the engine just sounds like a bag of nuts and bolts after a "high rev"?
These reports are blown way over the top IMO
Old 03-05-2018, 09:36 PM
Tmistry
Tmistry's Avatar
I agree. Can you imagine if air cooled cars had DME info? If the engine is running strong and the leak down is good, what's the issue? These cars can take a lot more than most of us will ever put them through.
I'd like to see the DME on a purely track driven beast. Anyone seen a savage DME report? Seems like one would being bragging rights in certain circles.
Old 03-05-2018, 10:09 PM
Skwerl
Skwerl's Avatar
I've seen tons and tons of cars with a bunch of 5s and 6s that still run strong and pass all relevant health checks, but strangely have never once heard of a TT breaking from old over revs. If your money shift breaks something, you tend to know it right away.
The prevalence of 997s with over revs makes me think a pretty sizeable chunk of aircooleds would have them, too.
What's funny to me is the guys who buy into the Mezger Mystique for its race-bred heritage and legendary durability but then run for the hills if they find out the car was actually driven around redline.
Quick Reply: DME - Not good news for me
