2007 997.1 No start - No crank
I have been waiting for the failure to recur and it has not. Based on how it is behaving I am leaning toward ignition switch.
Obviously if it happens after I replace the switch, I would do the starter. I need to check the wiring now that it starts.
Question: Suppliers? Pelican, Suncoast, AutoAtlanta, someone else?
I will update the thread with any results.
Ed
Ed
Ed
Ed
For an ignition switch, which is not terribly expensive, I would opt for the OEM part.
I just checked pricing on Pelican versus Sunset for the switch. Pelican shows it for $203 while Sunset sells it for $163.
Update: I installed a switch as the first step in solving this issue, and so far after 4 starts/stops the vehicle has started each time. Obviously I need more attempts to confirm this, but the last go around prior to replacing the switch, the car would no re-start almost every time after a 20 - 30 minute drive.
Fingers crossed. Will update again if it fails and I move to R&R the starter.
BTW, the space available is quite tight, I had to unhook the brake switch wire in order to get just enough room to do the R&R. I wish the kick panel was 2 piece like my Audi, would have been a breeze if I could have pulled that panel, but looking at what was involved, I decided against trying that.
Ed
Ed
So...... cleaned the car up very nice yesterday, drove it around a bit, no issues. Took it out today to ref a couple of games at different rinks, stopped to get gas, get home, turn it off. No start.
So I am sourcing a starter and will do that job next. I will add my old switch to my good used parts pile.
I also have to deal with the clutch slave (disappearing PS fluid) and would like to do both at the same time, but I am not sure which way I want to go, GT2 conversion or just pull the coupler and replace the slave. Decisions, decisions.
Ed
Ed
Ed
Ed
FWIW I had a similar starting issue recently and had it diagnosed as the starter. The local Porsche service put in a new starter and it was CDN$333 for the labour (to both diagnose and replace) and $995 for the starter (Bosch starter that came with complementary Roadside Assistance for 2 years). Starts great now and clearly turns much faster than the faulty starter did even though it seemed quite normal to me.
Update:
2 things:
1. When I went to pull the starter, I undid the 13mm nut and pulled the 3 large wires and off came the trigger wire from the smaller post. It had no nut on it.
2. When I started to install the reman starter, it was a different size (the windings/motor section was longer), so I checked and it is for a '90 - '98 3.6, not the 997 series
So, 2 more things:
1. I think the starter is OK and I would like to know who pays so little attention to detail they don't secure connections to a part (my guess is the part was replaced unless the 9mm nut tends to come off - which would be a first on any car I have owned)
2. I have to send the improper starter back and depending on what I decide on #1, maybe not re-order the correct one
A non existent nut on the solenoid trigger falls well into the possible explanations for an intermittent and random starter failure. Unfortunately, I should have gone for the dirty job (R&R the starter) before doing the cleaner one (R&R the ignition switch) and saved myself $180 and 2 hours of time. Of course if I choose to re-install the original starter with a nut on the trigger wire, I still may have a problem, but my gut tells me I have found the issue.
My guess is that this will be a first for any 997 owners out there and is a perfect example of why I like to do as much of my own work as possible.
Ed
2 things:
So, 2 more things:
Ed
