Need a good toe hook license plate frame pls
Received 5,388 Likes
Rennline.
Originally Posted by tguaturbo
Thanks. Saw one of those and it looked solid.
http://www.moweraxle.com/licenseplat...censekits.html
Solid, had it on my 993 in CA.
Live in a no front plate paradise now.
Thanks. Just ordered this one because a local friend has it also and has been very pleased with it.
Tom
I'm sure it will be good. Here's a tip though. All on these tow hook mounts rely on a bolt that screws into the point. They turn because they aren't tight enough. Don't worry about the strength of the mounting point, it's engineered to tow the car. If your mounting bracket is well engineered you need to torque the thing down reaaalllly tight, then reposition the plate to be level. You generally use the plate and bracket to do this so it helps if it's been well made.
Also, you can place the plate pretty much anywhere, up, down , left right, to get the least worst look, (I hate front plates) or impact airflow to radiators.
