Cobb AP Tuning in Charlotte or near Eastern NC
Gents,
I shall submit my NO LONGER A LURKER thread in about 2 days when the check is finally sent from my bank to his...but here is a teaser shot.
Ok so the car has a Speedtech 2.5 in system with 200 cell exhaust(probably swapping for a 3in catless), champion intercoolers, and a Cobb AP tune.
What are some simple bolt ons other than bigger turbos that I can get for a little more juice and smoother turbo spool? Also where should I go to get the Cobb tuning done, I live in eastern NC? Had the car not come with the Cobb AP I would have gone with Kevins tune.
If you want a custom Cobb Tune I would try to find somebody local in your area to work with if you can find them. Ideally, they will have access to a dyno and will be willing to follow through on any issues you may encounter. Otherwise you might be better off with OTS Cobb and could probably deal with Cobb directly. I've already been down the custom Cobb Tune path and that is my .02.
Honestly, remote tuning from a Cobb expert regardless of their location has worked brilliantly for myself and many others.
I would highly recommend Sambo at ByDesign. He set me up with a custom baseline tune, looked my logs, made a few tweaks, gave me a few suggestions and my car has been a monster ever since. The custom tune made as much of a difference over the OTS Cobb map as the OTS did over the stock map, especially in low/mid throttle and drivability. He's dialed in to what these cars need and will get you where you want to be.
